Timing of heartbeat LED is off
Migrated my test code from a 18F26K22 (max 3Kohm impedance on ADC) to a 16F1937 (max 10K).
Datasheet: https://ww1.microchip.com/downloads/...ets/41364E.pdf
32 MHz internal clock is on page 74
I tried a gazillion permutations of the clock settings but I can't seem to get it to blink ON at 1 second intervals.
Pause 15 takes about 1 second from ON to ON. :confused:
__CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
__CONFIG _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_ON & _STVREN_OFF & _BORV_LO & _LVP_OFF
DEFINE IRCF = %1110 ' to enable 8 MHz
DEFINE SCS = %00 ' system clock determined by FOSC
DEFINE OSC 32
'DEFINE TUN = %000000
ANSELA = %00000000
ANSELB = %00000000
ANSELD = %00000000
ANSELE = %00000000
TRISA = %00000000
TRISB = %00000000
TRISC = %00000000
TRISD = %00000000
TRISE = %00001000 ' E3=MCLR
LEDblink var PORTB.5
LEDblink = 0
Mainloop:
if ledblink = 0 then
LEDblink = 1
LEDblink = 0
Pause 15
goto mainloop
I bow in humbleness and await the appropriate mockery.
:D
Re: Timing of heartbeat LED is off
none of which are known PBP defines
which means that the chips osc is running with POR values
what are the POR values
Attachment 9706
fosc= 0.5 MHz
osccon = ( IRCF << 3) | SCS
might work
First off, you should use CON to define a numeric constant instead of DEFINE
Next, since the intosc defaults to 500KHz at startup, that's outside the range of the 4xPLL which is spec'd from 4MHz-8MHz.
While it might work, I'd leave the CONFIG setting for the PLL off and enable it when you change the osc freq
Something like this should work:
__CONFIG _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_LO & _LVP_OFF
DEFINE OSC 32
' OSCCON register settings
SPLLEN CON %1 ' PLL enable
IRCF CON %1110 ' to enable 8 MHz
SCS CON %00 ' system clock determined by FOSC
OSCCON = (SPLLEN<<7) | (IRCF<<3) | SCS
Thanks guys. I've been away for far too long.
Tumbleweed's code worked on the first try. :cool:
