Re: PBP and IDE/programmer
Thanks and appreciated.
It's a 10year old thread...hope it's still relevant.
What's happeend to picbasic? Besides the shopping aspect of the web site is still working all else has seemed to have ground to a halt?
That is true. People are getting old, things too!
Melabs will not develop PBP anymore and the latest version of PBP needs MPLABX assembler to work. Please DO NOT download the latest MPLABX. Only version 5.35 will work and obviously the PIC that this version supports.
Yes that is very true!
Hopefully some young enthusiast buys out PBP, I'd happy to be a VC for this. Keep me posted if you do hear of anything.
Haven't got a led flashing yet....but have managed to get MCS to run and download to the PIC so that's a start.
thanks again,
Rob.
We all hoped that PBP would find a way in the future but now I am convinced this will not happen.
People change, so microcontroller also do. Arduino, Pi, Python, and many many others are out there. PBP is considered outdated...
Can only hope!!! I think it still has a market, just product is not being marketed and it's a difficult experience to get started with.... IE
Can't get my first code running...
Have given up trying to get MPX to work even with the rev. you suggested.
Hence current on version 3.65 of mpx.Only need this installed for the pickit3 to work mcs.
I've got MCS now comipling and writing to the micro, but code doesn't appear to be executing.
Have tried a few variation of registeres but program is as follows:
CONFIG FOSC = RC ;
TRISB = %00000000
LED0 VAR PORTB.2 ' Assign name "LED" to PORTB.0
LED1 VAR PORTB.1 ' Assign name "LED" to PORTB.0
mainloop:
High LED0 ' Turn on LED connected to PORTB.0
High LED1 ' Turn on LED connected to PORTB.0
Pause 400 ' Delay for .5 seconds
Low LED0 ' Turn off LED connected to PORTB.0
Low LED1 ' Turn off LED connected to PORTB.0
Goto mainloop ' Go back to loop and blink LED forever
Via the program options of MCS using the PCK3cmd.exe from the MPLABX with the following command line:
-P$target-device$ -F$hex-filename$ -B -E -M -L
Programming seems to work but have no flash led! MCLR is held high..
I'm sure I'm missing somethign so obvious...but any pointers appreciated.
Connecting to MPLAB PICkit 3...
Currently loaded firmware on PICkit 3
Firmware Suite Version.....01.49.09
Firmware type..............PIC18F
Target voltage detected
Target device PIC18F45K20 found.
Device ID Revision = 1c
Erasing...
Erase successful
Device Erased...
Programming...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x7f
configuration memory
Programming/Verify complete
PICKIT3 Program Report
17-Jun-2024, 15:02:41
Device Type:PIC18F45K20
Program Succeeded.
Batch Mode Count : 1
Batch Mode: Press Enter to repeat the same operation ! Enter (quit) or (q) to abort the operation
Rookie mistake should have had INTIO67 not RC for the clock!!
Ahhh
I hope you do not have many MPLABX version installed. Normaly they shouls co-exist but could also mess up things. Better be safe and uninstall all other version except 5.35 that works with the latest PBP.
As a programmer, I use Elnec BeeProg 2 and PicKit3 with a stand alone program by https://pickitplus.co.uk/Typesetter/ that supports Pickit2 and Pickit3 at the same app.
I've removed all other installs and switched to 5.35.
But I'm having problesm with 12F508 micros, seem like I get 2 chances to program the micro then, I get failed to program device error.
Swap out the micr and same thing. Purchased from Mouser so doubt it's a dodgie chip and it's definetely not a 12C508.
Scratching my head on that one!
I've ordered the programming software you pointed me to, just waiting on the license and see how that goes.
Rob.
sounds like you have over written the osccal/ value stored at the top of memory for 12f508.
Most programmers will not reprog that chip when the value is missing.
The old pickit2 can reset a value there, with a bit of work. Pk3 might be able to do it too.
Not sure how I would have and looking at that register even any value 0's or 1's, it would still work??
Considering the application doesn't require any precise timing, should I provide a value regardless?
But did find this as another possible reason:
https://forum.microchip.com/s/topic/...6KtEAK/t254415
Anyway I've got 5 pics left, hopefully I'll work it out soon!
Rob.
are your cable longer than 15-20 cm?
Ioanins
Got it worked out!
Again a probably another rookie mistake...Solution was to increase the VDD to 4V! minimum. (software does recommend 4.5V) but 4 seemed to work fine.
Thanks Ioanins for the pickit3 plus software recommendation! That's what discovered the problem.
Great little program, works heaps faster then MPLAB X pck3md
Also integrated within MCS using the pickitcommand exe, hence can delete the bloated software MPLAB X!
My 5 spare 12F508 are breathing a sigh of relief!
Big thanks again,
Rob.
P.S Ioanins I'm coming to your lovely country next week for Holis, by any chance will you be in Athens on the 10th July? I owe ya a beer!!!
Glad you got it working!
Yeah, that stand alone revive of Pickit application is my favorite! Love it! Fast, compact and easy to use.
I think you cannot ged rid of the MPLABX as the PBP needs the assembler and the related files.
A beer would be very nice to have together but unfortunately I am about 560Km north of Athens. My town is Thessaloniki (second biggest own in Greece). Hope you visit places near the sea side or islands and feel the greek summer thing! Really hot here! Wish you a pleasant stay and if you like ancient places, Acropolis and the museum of Acropolis is a must to visit.
robertg
The programming spec document for the 12F508 states that the min VDD for programming and bulk erase is 4.5V, so I'd increase that just to be safe.
https://ww1.microchip.com/downloads/...Doc/41227E.pdf
I'm heading to the islands. Maybe another time!
Completely removed mpab x and no probs to compile.
Rob.
Once I realised it was the issue, went looking and found exactly that. Thanks.
