Storing a variable in EEPROM
I'm trying to store a numeric variable into a PIC18F2550 EEPROM.
I would like to store the variable and then call it later on.
This is what i use to store the variable
DelayIn VAR WORD
Delayin = 120 ' This is in Seconds
Write 5, Delayin.Byte0
Write 6, Delayin.Byte1
And to Read
Procedure:
Read 5, DelayOut.byte0
Read 6, DelayOut.Byte1
Pause DelayOut * 1000 ' Multiply DelayIn by 1000 to give seconds
For Loop = 1 to 5
Red = 1
Pause 100
Red = 0
Pause 100
Next Loop
If the variable was set at 120, i would expect the pause around 120seconds (2mins) before the LED flashed, but its only around 53 seconds. Therefore i am guessing i am not storing the variable correctly.
I've checked the manual and this is the example it gives.
Is there a better way of completing this type of task?
