Hello to the Community.
Is the Shiftout command possible for a PIC12F675?
I ride a program using this command but my logic analyzer does not show me any pulse of Data and Clock!
Thanks.
Thanks.
Here is the test program...
' Programme: Shiftout Test PBP (c)Roger LEGAT 07-2023
' RX Tester---> PIC 12F675
' PicBasicPro Compiler V:2.40 ---> 393 Words used
'*** PIC Pinouts/Specifications
' PIC 12F675
' __ __
' Vcc +| U |- Gnd
' GPIO.5 x| |< GPIO.0
' GPIO.4 >| |> GPIO.1 _DIO
' GPIO.3 >| |> GPIO.2 _CLK
@ Device Pic12F675, intrc_osc, wdt_off, pwrt_on, mclr_off, protect_off
DEFINE OSC 4 ' Pulsin/Pulsout Resolution =10µsec => 1ms=100
' (Pulse Value of 1msec x10 =1000) [x10]
' Pause =1msec => 1msec=1 1sec=1000
Include "modedefs.bas" ;for shiftout command
CMCON = 7 'Comparator Off
ANSEL = 0 'Set Port to Digital i/o
ADCON0 = 0 'All ADC Off
Asm
bsf STATUS ;Bank 1
call 3FFh ;Get the CAL value from 3FF addresse YOU WRITE BEFORE !
movwf OSCCAL ;Calibrate
bcf STATUS, RP0 ;Bank 0
Endasm
'*** In/Out pins ..................................................
Output 1 : _DIO var GPIO.1
Output 2 : _CLK var GPIO.2
'*** Variables/Constants
Pack VAR BYTE ;Byte to send
'=== MAIN PROGRAM =====================================================
Pack = 255
MainLoop:
Shiftout _DIO,_CLK,LSBFIRST,[Pack\8] 'Send Byte
Goto MainLoop
;=========== END OF PBP =================================================
Maybe it is better to define the output register more convenitional.
Try
TRISIO = 0
DIO VAR GPIO.1
CLK VAR GPIO.2
and report back how is doing.
I'm trying to understand and learn:
What might be the consequences if I set my ports as follows:
Dio var GPIO.0
or
Symbol Dio = GPIO.0
Does this make a difference to the way the program is processed?
Originally the problem I think was this syntax:
I do not see how this can compile.
Hello,
And yet the compiler didn't give any errors!?
I'm going to keep your suggested syntax anyway.
Concerning my problem with the Shiftout command, I note that a problem existed with this command for the Picaxe 08M2 (which is in fact a PIC12F1840).
The Shiftout command was not possible for this Picaxe and it was necessary to create a small routine explained in the Picaxe manual.
Before continuing my tests, I wondered if such a problem could also be encountered with my Pic12F675... ?
In PBP I never encountered any problems with SHIFTout or SHIFTin commands.
I pressume you will not have too.
Yes but you defined wrong. For example _DIO var GPIO.1 is not the same as DIO var GPIO.1
Ah?
This unnderscore character has an influence for PBP?
I usually used this character to identify my entries or outputs on the MCU!
To come back to my original question about the SHIFTOUT command, here's the program I'm trying to run.
Unfortunately, I've noticed that the SHIFTOUT command doesn't produce any signals on the SDA and SCK output ports!
Any idea why?
Code:'*****************************************************************
'* Name : Pulsin to TM1637.PBP *
'* Author : RGL *
'* Date : 01/08/2023 *
'* Version : 1.0 *
'* Compiler : PBPro 2.6 *
'* Notes : 415 words used *
' PIC 12F675
' __ __
' Vcc +| U |- Gnd
' GPio.5 | | GPio.0
' Pulse GPio.4 >| |> GPio.1 SDA (Data)
' GPio.3 | |> GPio.2 SCK (Clock)
'DEFINE OSC 4 ' Pulsin/Pulsout Resolution =10µsec => 1ms=100 DEFAULT VALUE
'OSCCAL = $4C (344C placed manually in the hex file at 3FF address)
Asm
;bsf STATUS ;Bank 1
;bcf STATUS, RP0 ;Bank 0
Endasm
TRISIO = %010000 'GPIO.4 Input=1. All other Output=0
SDA Var GPIO.0 'Serial Data pin
SCK Var GPIO.1 'Serial Clock pin
Pulse Var GPIO.4 'Pulsin pin
CHR1 VAR BYTE ;4 Byte to send
CHR2 var Byte
CHR3 var Byte
CHR4 var Byte
Value VAR WORD ;Average Pulsin Value to display
Measure VAR word ;Intermediate and successives readings
i VAR BYTE ;Working variable (20 successive measurements)
' TM1637 Commands
;CMD1 CON $40 'CMD1=$40 Write command Auto-increment Mode (Default Mode)
CMD2 CON $C0 'CMD2=$C0 Start 1st digit position(left most = 1st digit)
CMD3 CON $8C 'CMD3=$8A is the end command that turns the display ON and sets brightness to 69%
; Definition of the 10 characters in the EEPROM : 0-9 +Blank
; (Eeprom Starting address at 0)
; EEPROM(0 1 2 3 4 5 6 7 8 9 10 ) Pos10 = Blank
DATA @0,$3F,$06,$5B,$4F,$66,$6D,$7D,$07,$7F,$6F,$00 ; Write to Eeprom
'=== INIT TM1637 =====================================================
Gosub StartSeq
SHIFTOUT SDA, SCK, 0, [CMD3] 'SHIFTOUT brightness
Gosub AckSeq
gosub StopSeq
MainLoop:
Value = 0 : Measure = 0 'Initialize Value and Measure
For i=1 to 20 '20 successive measurements for stabilisation of the display
Pulsin Pulse,1,Measure
Value = Value + Measure
Next
Value = Value /20 ;Average PULSIN value
Value = Value * 10 ;Conversion to uS @4Mhz
; Decomposition Method:
CHR1 = Value / 1000
If CHR1 = 0 then
CHR1 = 10 'Blank Char.
Else
CHR1 = CHR1+$80 '+Decimal point
Endif
CHR2 = Value / 100 // 10
CHR3 = Value / 10 // 10
CHR4 = Value // 10
'This sequence outputs now all 4 characters to the Display
Gosub StartSeq 'SHIFTOUT Mode 0 - LSB First, Clock normally low
SHIFTOUT SDA, SCK, 0, [CMD2] '1st Digit Adrress
Gosub AckSeq
SHIFTOUT SDA, SCK, 0, [CHR1] '1st Digit value
Gosub AckSeq
SHIFTOUT SDA, SCK, 0, [CHR2] '2e Digit value
Gosub AckSeq
SHIFTOUT SDA, SCK, 0, [CHR3] '3e Digit value
Gosub AckSeq
SHIFTOUT SDA, SCK, 0, [CHR4] '4e Digit value
Gosub AckSeq
Gosub StopSeq
Goto MainLoop
'============= SUBROUTINES ====================================
StartSeq:
High SCK
High SDA
Low SDA
ACKSeq:
Low SCK
High SCK
Low SCK
StopSeq:
Low SCK
Low SDA
High SCK
High SDA
'=============== END OF PBP PROGRAMME =========================================================
