More MCS+ Bootloader Questions
I am strongly considering buying MicroCode Studio Plus in order to use the bootloader with a PIC18F2525. But before I drop the $50...
1. Will the bootloader work without the MCLR/DTR line? I only need the circuit to look for the boot loader when it is first turned on (or manually reset). I don't have any "spare" pins in this design, and the MCLR pin is already being used as an Input, and even the USART RX and TX lines will be used as normal I/O lines for other functions when the bootloader is not connected.
2. Ideally I'd also like to skip using the MAX232 chip and just use 2 resistors as shown in the PBPRO manual (SerOut/SerIn). Has anyone had success with this for bootloader operation? Is it reliable?
thanks in advance
Jim
www.lasertagparts.com
