Problems with program
Hi guys again. I know I shouldn't keep asking for help but this time i really need help. Cause my progress report 2 is just next week. Not much has been done which is omg omg for me now. lolz.
I am now doing a sender and receiver device. The receiver device has a button for it to reply to the sender but it should only allow this to happen when 2 conditions are satisfied, 1-the button is pressed and 2-when the led lights up. My problem is that I have tried using the IF...THEN...ENDIF statement to check for the button and LED. For eg. PORTA.0 is the LED and PORTA.1 is the switch, so...
IF (PORTA.0 = 1) AND (PORTA.1 = 0) THEN
It doesn't work. So I assume that the IF...THEN statement treats PORTA.0 as an input and some error might occur there. Anyone has any idea how to go about this problem? Thanks in advance.
If you post your program and/or schematic. we could point you in the right direction, but as it stands we don't know how your PIC is detecting the LED is lit, so it's difficult to answer.
The LED is actually connected to the chip itself. When the receiver receives a data from the sender, the receiver will light up this LED. Only when this LED is on, then the user is allowed to press a button to send a reply.
The LED is connected to Port A pin 0
The button is connected to Port A pin 1
The Receive pin is Port B pin 0
The Sending pin is Port B pin 1
The carrier detect pin (from the RF transceiver which will switch to low when a signal is detected) is Port B pin 2
My program looks roughly like this:
DEFINE OSC 20
DEFINE SER2_BITS 9
REC VAR BYTE
DATA VAR BYTE
TRISA=%00000010
TRISB=%00000001
TRISC=$00
RECEIVE: IF PORTB.2=0 THEN
SERIN2 PORTB.0,8380,RECEIVE,[WAIT("TUV"),REC]
HIGH PORTA.0
REPLY: IF (PORTA.0 = 1) AND (PORTA.1 = 0) THEN
SEROUT2 PORTB.1,8380,["TUV",PRESS]
LOW PORTA.0
This is actually a small part of my whole program. The finished receiver should be able to take in message from 3 senders.
OK, we've got something to work on now...
The problem you're having is that you've set A.0 for Output, and then performing a Read (Input) operation on it... sometimes this doesn't work and sometimes you can get away with it... to be bullet-proof try this...
LEDStatus var bit ' Add this variable
HIGH PORTA.0:LEDStatus=1
REPLY:
IF LEDStatus=1 THEN
IF PORTA.1 = 0 THEN
LOW PORTA.0:LEDStatus=0
If it still doesn't work then you must ask yourself...
Is PORTA.1 Low?
Have I remembered that A.1 needs a pull-up Resistor?
Melanie
Ok thanks. There should be any problems with the hardware cause I have already tested it before and it works fine. I'll go tryout your solution. Thanks alot.
