16F88 and temperature sensor
I have one open pin available on a project I'm working on. I would like to add a temperature sensor to give me air temp. What is the best option to go with?
I've looked at the LM35 but it requires a negative source to utilize the full range....thats not an option for me. Thoughts?
Everything in the Datasheet ...
Hi, Ben
The Only disadvantage WAS in Analog meters : needed to have a precise 2.7315 ref voltage to calibrate ( TL 431, generally ...).
nothing to add, except it's analog ... take care with long cables, if so ...
3 Cylinders KH 500 for ever ...
Originally Posted by DynamoBen
I'm looking to do time and temp on a motorcycle. Originally I was looking at the I2C temp ICs. This was due to the fact that they are easy to interface to and are fairly accurate. However my concern is protecting the electronics from the environment and getting fairly accurate outside air temp. (within a degree) However if there is a way to use these ICs and keep the rest of the electronics out of harms way I'm all for it.
This is what started my thread. My hope is that if you know my application that will give you insight into what I'm trying to do.
Hi, Ben,
There's no problem on a bike ...I have such a thermometer home for outside temp, a silicone seal and therm schrinkable protects the LM from snow and rain for now 15 years !!!
I think it would be convenient to use shielded cable ( for Alarm wiring i.e. ) not to be disturbed by the ignition system ( ? )
If I understand you well , you're looking for a freeze alert smart device ... isn't it ???
read you soon
