12F683 EXTERNAL CRYSTAL CONFIG for DTMFOUT statement
Hello,
I currently using a 12F683 at 8mhz internal osc, with this code below and it's working fine no problem at all.
; __config _INTRC_OSC_NOCLKOUT & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _BOD_OFF & _CP_ON & _CPD_OFF
OSCCON = $70 ; 8mhz
This is the config set from meConfig setup program:
__config _INTOSC & _WDT_ON & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_ON & _FCMEN_ON
Now I need to use the same 12F683 chip with an 16mhz and/or 20mhz external crystal,
What do I need to change to make it work at 16 or 20mhz external crystal, please provide both config 16 and 20mhz crystal.
Thank's to reply.
Re: 12F683 EXTERNAL CRYSTAL CONFIG for DTMFOUT statement
At the top Define 16mhz or 20mhz
OSCCON = 0
In the config replace
_INTOSC or _INTRC_OSC_NOCLKOUT with _HS_OSC
Thank's Mark_s for the quick reply,
I did changed theses lines, but there's one thing is odd, I have to turn MCLRE_ON to "on" if it's "OFF" nothing is working properly
look at my listing, I did this to test if the Pic is running at 16mhz,
Cheer,
__config _HS_OSC & _WDT_ON & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_ON & _FCMEN_ON
OSCCON = 0
DEFINE OSC 4 ;RUN 4X 16MHZ CRYSTAL
;DEFINE OSC 16 ;RUN 1X 16MHZ CRYSTAL PAUSE 1000 = 1 SEC
ANSEL = 0 ; Set all digital PULLUP Resistor page:10
CMCON0 = 7 ; Analog comparators off
LED Con 0
DO ; main loop
TOGGLE LED
PAUSE 1000
LOOP
jackberg1
Cheer,
OSCCON = 0
LED Con 0
DO ; main loop
TOGGLE LED
PAUSE 1000
LOOP
----------------------------------------------- NEW CONFIG SEEM TO WORK ----------------------------------------------
IF DEFINE OSC 4 LED BLINK 2 times on-off / 1 sec FOR 16MHZ CRYSTAL
IF DEFINE OSC 8 LED BLINK 1 times on-off / 1 sec FOR 16MHZ CRYSTAL
IF DEFINE OSC 16 LED BLINK ON 1 SEC, BLINK OFF 1 SEC, FOR 16MHZ CRYSTAL
Let me know if this new config is correct.
Thank's again for comments.
; config setup from meConfig program
__config _HS_OSC & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_ON & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
;OSCCON = 0
;DEFINE OSC 4 ;RUN 4X 16MHZ CRYSTAL
;DEFINE OSC 8 ;RUN 2X 16MHZ CRYSTAL
LED Con 0
DO ; main loop
TOGGLE LED
PAUSE 1000
LOOP
