All outputs/Ports in LOW state ?
Hello to the community.
With a Basic Stamp 2sx, it is possible to initialize all outputs (all ports) to the low state with the command OUTS=%0
However, this does not seem to work at compile time (PBP2.46)
For a PIC16F814A, I solve with the code below, but isn't there a simple command for this?
CODE:
'All ports Low state
'OUTS = %0 'Does not work after compiling!
for i = 0 to 12
low i
next
Thank you.
Re: All outputs/Ports in LOW state ?
I don't know what a 16F814A is, there doesn't seem to be such a device. Do you mean (the ancient) 16F84A?
If your device have a PORTA and a PORTB
TRISA = 0 ' All pins of PORTA as outputs
TRISB = 0
PORTA = 0 ' All pins of PORTA logic low
PORTB = 0
If the device has any analog functions (comparator and ADC) then those will most likely need attention before the pins will function correctly as digital pins.
Thanks Henri.
Yes, 16F84A. (Typing error !)
With PortA and PortB.
