picbaisc pro compiler routines "question!"
hi all
my question is:
picbasic pro has too many routines and built in functions so
if i use for ex. the routine "pause 20" in a line it will be placed in a program location ,if i reused a "pause 20" again will the compiler place another code in the program memory for that or use the previosly one used?
if i declared a sub-routine that i will use many times as:
delay:
pause 20
is that a solution and better than writting "pause 20" every time i need ?will it affect the program ?
thnx
bye
