Problems with Programm Code
I have a little problem with my little codes.I push the buttons but dont receive data to PC ,but when i send data from PC to PIC 16F870 I receive data back,this is OK.This just happen when I put the codes together in Main:
But When I live just the Buttons code in Main then data are incoming to PC.
I think I can not use together RCIF and Buttons,I have a 4 Mhz Crystal and Max 232N.
Define LOADER_USED 1
Include "modedefs.bas" ' Mode definitions for Serout
DEFINE HSER_RCSTA 90h ' Set receive status and control
DEFINE HSER_TXSTA 24h ' Set transmit status and control + BRGH=1
Define HSER_BAUD 9600
DEFINE HSER_CLROERR 1
ADCON1 = 7
A0 var byte
A1 var byte
A2 var byte
A3 var byte
' Alias definition
RCIF VAR portc.7 ' Receive interrupt flag (1=full , 0=empty)
TXIF VAR portc.6 ' Transmit interrupt flag (1=empty, 0=full)
' Variable definition
SerialData var byte
' Hardware initialisation
pause 10 ' safe start-up delay
if RCIF then ' incomming data?
hserin [Serialdata] ' take it ' I think here is the problem
hserout [Serialdata] ' send it
BUTTON PORTA.0,0,255,1,A0,1,ML1
BUTTON PORTA.1,1,255,0,A1,1,ML2
BUTTON PORTA.2,1,255,0,A2,1,ML3 ' Or here I can not use all this
BUTTON PORTA.3,1,255,0,A3,1,ML4 together
goto Main
ML1:
Hserout ["M1"]
ML2:
Hserout ["M2"]
ML3:
Hserout ["M3"]
ML4:
Hserout ["M4"]
Please I need Help.
Thanks a lot
bye Pesti
