		How to prevent variable going below zero?
 reader:
 adcin 0,Z
 IF Z>100 AND Z<130 THEN I=I+5
 IF Z<100 THEN I=I-5
 if i>255 then i=255
 if i<5 then i=0
 HPWM 2,I,10000
 XY=I
 gosub decoder
 goto reader
 Here is the simple code, the part if i>255 then i=255 works fine, but the part if i<5 then i=0 does not, because when i value goes below 0, it does not go below zero, it goes to 65535 and so on, completely messing whole code. Any ideas?
		Re: How to prevent variable going below zero?
		The convention used by most software is that if the most significant bit is set, then the number is negative.
		Picbasic has no idea about negative numbers, anything goes below 0 gets deducted from 65535.
		First, you didn't include what size your "z" & "i" variables are; var BYTE or WORD?  If you declared them as BYTEs then 256 becomes your roll-over value, not 65536.  If you are adding and want to check to see if your variable went over 255 and rolled over, the STATUS Register will show "STATUS.C = 1".  If subtracting and want to see if it rolled from 0 to 255, "STATUS.C = 0". Look in your data sheet for the STATUS Register and how it works.
		mike would you like to provide some pbp code that demonstrates use of status register following pbp addition or subtraction
 the status reg here is not in any way influenced by the subtraction result
 i = byte
 j=8
 i=6
 while j
 status=1
 i=i-1
 s=status
 debug 13,10,"status ",bin8 s ,"  i ",    dec i
 j=j-1
 wend
 result
 status 00011001  i 5
 status 00011001  i 4
 status 00011001  i 3
 status 00011001  i 2
 status 00011001  i 1
 status 00011101  i 0
 status 00011001  i 255
 status 00011001  i 254
		Yes variable is WORD, because if use BYTE, IF I>255 statement also wont work :D
i = byte
 j=8
 i=6
 while j
 status=1
 i=i-1
 s=status
 j=j-1
 wend
 result
status 0001100 1  i 5
status 0001100 1  i 4
status 0001100 1  i 3
status 0001100 1  i 2
status 0001100 1  i 1
status 00011 10 1  i  0
status 0001100 1 i 255
status 0001100 1  i 254
 You don't state what PIC this is for, so I randomly grabbed the data sheet for a PIC16F1824; STATUS Register 3-1, page 24.
 STATUS <7:5> = Unimplemented, read as 0
 STATUS.4 = TO:  Time-Out bit
 STATUS.3 = PD: Power-Down bit
 STATUS.2 = Z: Zero bit
 STATUS.1 = DC: Digit Carry
 STATUS.0 = C: Carry
 You can see when you reached zero the STATUS.Z reflected that.  However, you alter the STATUS Register in your code.  About the only thing you can change is the C bit.  Delete the "status=1" line and try again.
 your assertion is
 if your assertion was correct it would not matter  but its a12f1840
 i repeat
 for any chip
		a look at the lst file yields the reasons .
 the status reg is not useful when you add or subtract a const 1
 if you use a number greater than 1 or another var then the code does a proper addition/subtraction rather than inc/dec and sets status reg correctly
 caveat emptor
 Re-read the single line I sent. I was not talking about PBP. I'm talking about representation of integers in a binary system. Read this article: https://www.cs.cornell.edu/~tomf/not.../twoscomp.html What most software developers do when they want to know when the variable goes "below zero", is look at the most significant bit. If it is high, the number is negative, if it is low, the number is positive. Since you are using a word, then your largest positive number will be 32768.
		And since here is PBP forum, not general representation forum, I'm asking how to deal with this in PBP :)
		Will this work for you?
 iflag var bit
 let iflag =0
 reader:
 adcin 0,Z
 IF Z<100 and iflag = 0 THEN I=I-5 'only if iflag = 0 it's OK to substract
 if i>255 then i=255
 if i<5 then i=0
 if i = 0 then let iflag = 1 'if i hits 0 put up a flag
 if i >= 5 then let iflag = 0 'once i hits 5 or more, reset the flag
 HPWM 2,I,10000
 XY=I
 gosub decoder
 goto reader
		In your original code, change
 IF Z<100 THEN I=I-5
 to this
 IF Z<100 AND I>=5 THEN I=I-5
		Try this:
 if Z.15 = 1 then
 Z = 0
 reader:
 adcin 0,Z
 IF Z<100 THEN I=I-5
 if i>255 then i=255
 if i<5 then i=0
 HPWM 2,I,10000
 XY=I
 gosub decoder
 goto reader
 1. tumbleweed caught one problem in your code.
 2. The variable I is altered some where? What check are you making ensuring it will not get a value to lead in negative results doing a -5 subtraction inside the reader routine?
		I like Tumbleweed's code. Shorter and more to the point.
		With a few proviso's mikes way beats it hands down
 IF Z<100 THEN I=I-5
 asm
 BTFSS STATUS,C
 CLRF   _I
 if i attempts to underflow its set to 0
		I like it how a simple logic problem CuriousOne had, lead to another topic with negative numbers and STATUS register!
 Quite interesting!
		anyone familiar with assembly programming will be well aware of the status reg and its use. what surprised me is that
 the value of the status reg was/is preserved even after the completion of the transaction. because the result is transferred from the
 working regs back into the result variable during the process i expected the status to be no longer representative of the calculation.
 surprised yet again !
		You are absolutely right! I do not trust that this may be the case for any PIC though.
 its a quick easy test to check, it works on all chips that i tried just make sure the compiler dosn't compress the subtract into a decrement
 i var can be byte or word
 j=8
 i=6
 while j
 status=1
 i=i-2  ;subtractant cannot be 1
 s=status
 j=j-1
 wend
		Well, thanks for checking out. Wow!
 reader:
 adcin 0,Z
 IF Z<100 THEN I=I-5
 if i>255 then i=255
 if i<5 then i=0
 HPWM 2,I,10000
 XY=I
 gosub decoder
 goto reader
 Using MAX and MIN operators  provided by the compiler ????
 4 times IF-THEN in a row,  ... Time to have a look to SELECT CASE ...
 BTW ... if you want your number staying between 0 and 255 ... use a BYTE, instead of a WORD ... :rolleyes:
 I'm just curious about what you try to do ( in the real world, of course ) with such a piece of code !!!
 That's his problem... he DOES want to use a byte but as he adds or subtracts to the byte value it wraps and gives false operation.
 The way I usually handle this sort of thing is to have a routine that does the addition or subtraction with a temp copy of the variable, and only update the variable if the operation is valid.
 You don't have to detect a negative number... what you want to know is if you add X to Y will it be < Y (wrapped 255) and if you subtract X from Y will it be > Y (wrapped 0). Don't modify Y until you know the answer. You can have the routine limit the results to 255 or 0 if that's how you want it to work, or ignore the operation.
		So this "wrapping" is compiler related issue and can't be fixed, as I understand?
		Technically, I solved this problem by making I change between 5 and 260, and outputting HPWM 2,I-5,10000.
		If you mean a compiler problem, no. It is not.
 If you mean how binary arithmetic works, yes. That is how you count, add or subtract in binary having byte, word or other size variables. In any case that is how you do it in decimal also but do not give it much attention.
 The "fix" is in the answers given already to you. SELECT CASE, test before updating for valid result, etc...
