I'm trying to generate multiple audio tones using a DAC/resistor ladder (currently 4 bit / 16 values - will scale up eventually), but am troubleshooting increasing the speed of this loop for a single tone. Originally I was using a sine lookup table, but for multiple tones it appears to be too slow. I'm currently using a roughed-in binary version of 'Bhaskara I's sine approximation formula', which eliminates any lookups.
However, the implementation I have currently is also slower than I'd like. I will scale up to a 20Mhz OSC at some point, but would like to get this loop <~25uS with a 4Mhz osc if possible.
My question is: what instructions in the loop below are computationally expensive, and what changes could be suggested to speed it up? I'm not sure how much additional overhead I incur with word variable operations as opposed to byte variable operations...?
Thanks in advance!
Code:define OSC 4
cmcon=7
timebyte var byte
x var byte
range var word
ampvar var byte
ampvar2 var byte
nvar var word
dvar var word
fvar var byte
negflip var byte
pausec1 con 25
TRISB = %00000000
timebyte=0
high porta.1
loop1:
x=timebyte & 127
range=128-x
range=range*x
nvar=range<<3
dvar=20480-range
dvar=dvar>>2
fvar=nvar/dvar
ampvar=8+fvar
negflip=2*timebyte.7
ampvar2=ampvar-negflip*fvar
PORTB=ampvar2
timebyte=timebyte+1
goto loop1
