I running the 18F452 PLL and I'm running into problems with the HSEROUT command. If I use a 4 MHz crystal the LCDOUT command and HSEROUT command work fine. If however I switch out the 4 with a 10 MHz crytal the LCDOUT command still works fine but the HSEROUT output garbage. I have used DEFINE OSC 16 and DEFINE OSC 40 to tell PBP what oscillator speed I'm running. Is there something else I need to do to go to 40 MHz?
