Hi everyone,
I'm starting a small program with Pic 18F2550, but it doesn't work well...
It should start with number 2 at Cnt_Lixo, and increment 1 every 1,5 seconds.
Sometimes (one in ten...), it starts well and increment correctly, but most of the times, it starts a 0, and never increment any number...
I'm lost.
__CONFIG _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
__CONFIG _CONFIG1H, _FOSC_INTOSCIO_EC_1H & _IESO_OFF_1H
__CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_OFF_2L
__CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
__CONFIG _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
__CONFIG _CONFIG4L, _LVP_OFF_4L
Define OSC 8 ' 8 MHz oscillator
Baud con 84 ' Baud rate = 9600 NonInverted 32 --> 19200 bps / 396 --> 2400 bps
PortA = $00 '
PortB = $00 ' --> Turn Off all Port's
PortC = $00 '
Tecla_Esq var PortA.4 ' Tecla Esq
Tecla_Dta var PortA.5 ' Tecla Dta
cnt_lixo var byte
cnt_lixo_1 var byte
cnt_lixo_2 var byte
cnt_lixo = %00000001
cnt_lixo_1 = %00000010
cnt_lixo_2 = %00000011
ADCON1 = %00001011 ' (5) Vss Referência, (4) Vdd Referência, (3-0) AN0 até AN3 = Analog, restantes ANx Digitais
ADCON0 = %00000000 ' (5-2) An0 Selected, (0) A/D Module Off
ADCON2 = %10000000 ' (7) Right Justified, (5-3) A/D Acquisition Time - 0 Tad, (2-0) A/D Clock - FOSC/2
CMCON = 7 ' (2-0) 111-> Comparator Off
OSCCON = %01110000 ' (7) Enter Slepp Mode on Sleep Instruction, (6-4) 8 MHz, (1-0) 1x--> Internal Oscilator 00--> Primary Oscilator ???
TRISA = %00111111
TRISB = %00000001
TRISC = %00010010
DEFINE LCD_DREG PORTB ; LCD data pins port
DEFINE LCD_DBIT 4 ; LCD low order data bit (0 -> PortX.0 - PortX.3 ou 4 -> PortX.4 - PortX.7)
DEfine LCD_RSREG PORTB ; LCD register "RS" select pin port
DEfine LCD_RSBIT 2 ; LCD register "RS" select pin bit
DEfine LCD_RWREG LCD_RSREG ; LCD Read/Write select pin port
DEfine LCD_RWBIT LCD_RSBIT ; LCD Read/Write select pin bit
DEfine LCD_EREG PORTB ; LCD Enable "E" pin port
DEfine LCD_EBIT 3 ; LCD Enable "E" pin bit
DEfine LCD_BITS 4 ; Number of LCD data bits (4 or 8)
DEfine LCD_LINES 2 ; Number of lines in LCD (1, 2, 4)
DEfine LCD_COMMANDUS 2000 ; LCD command delay in us
DEfine LCD_DATAUS 50 ; LCD data delay in us (0 - 255)
cnt_lixo = cnt_lixo + 1
Lcdout $FE, 1, " Cnt_Lixo_", dec cnt_lixo
Definicao_Data:
pause 1500
Lcdout $FE, 1,"Definicao"
if tecla_dta = 1 then cnt_lixo_1 = cnt_lixo_1 + 1 : lcdout $FE, $C0,"Tcl Dta" : pause 1500
if tecla_esq = 1 then cnt_lixo_2 = cnt_lixo_2 + 1 : lcdout $FE, $C0,"Tcl Esq" : pause 1500
lcdout $FE, $C0, dec cnt_lixo_1, "---", dec cnt_lixo_2, "//", dec cnt_lixo
goto definicao_data
Nuno
