I have a circuit that is reading 5 DS18B20 temp sensors at 16MHz (4 MHz x 4 PLL). The circuit works fine until I pop in a 10 MHz crystal then I lose the sensor that is running on parasite power. Is there some timing that needs to be modified in the owin and owout commands? I tried a totally different circuit and it works fine so I know the configuration setup is alright.
