if some difference in behavior in a 14bit core and 16bit core is that I did a circuit using pic18f252 and behaves rare
I did the same one code for both chips
depending wich pic you used before. Be sure that the new one don't have any analog or else Multiplexed stuff that the old have'nt. Double check the oscillator and fuse setting.
If yuo can post a part of your code... even if it's just the top, we can see if there's something bad with.
Thanks already find the problem..
The problem went that the pic was receiving more then 5.0v in a pin and himself it get crazy…
