Hello to all,
I have a pic16f628 and I want to count 10 pulses in RB0 for when ends RB7 on led, they can give me some example.
Thank you
Hello to all,
Thank you
here's one method using interrupt
without interupts but a loop.Code:@ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _BODEN_ON
TRISB=%00000001 ' Set RB0 to input, others to output
OPTION_REG=0 ' Enable internal pull-up on PORTB
' Interrupt on falling edge of RB0
INTCON = %10010000 ' Enable global interrupt
' Enable RB0 interrupt
LED VAR PORTB.7 ' connected between RB7 and GND via resistor
ClkIn var PORTB.0 ' connected between RB0 and GND
INTF var INTCON.1 ' RB0 Interrupt flag
Apulse VAR BYTE ' store the amount of pulse
on interrupt goto CountPulses
led=0
apulse=0
start:
if apulse<10 then start
' Here we got the 10 pulses
INTCON = 0 ' disable all interrupt
led=1 ' enable the LED
Z: goto z ' stay here 'till next system reboot
disable
CountPulses:
' Here is where the program jump every time the push-buton on
' RB0 is press.
apulse=apulse+1 ' add a count
while clkin=0 : wend ' wait untill the push button is release
pause 50 ' debounce time
intf=0 ' reset interupt flag
resume ' Get out of here
enable ' re-enable interrupt
Using internal counter(TMR0) and polling TMR0 overflow flag and RA.4 as input instead of RB0Code:@ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _BODEN_ON
OPTION_REG.7=0 ' Enable internal pull-up on PORTB
led=0
apulse=0
repeat
if clkin=0 then
pause 50
apulse=apulse+1
until apulse=10
led=1
Here:
goto here
Almost the same as above but polling only the TMR0 registerCode:@ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _BODEN_ON
TRISB=0 ' Set output to all i/o
TRISA=255 ' set input to all
OPTION_REG=%11111000 ' TMR0 clock source = RA4
' increment counter on high to low transistion
' prescaller assign to WDT
' prescaller rate 1:1
CMCON=7 ' disable analog comparator
INTCON = %00100000 ' enable TMR0 overflow interrupt
T0IF var INTCON.2 ' TMR0 Interrupt flag
TMR0=246 ' pre-load TMR0 to have an Interrupt after 10 pulses
' TMR0 is a 8 byte Register so 246+10=256=interrupt
led=0
WHILE T0IF=0 : WEND
LED=1
Z: GOTO Z
I prefer the last one, produce really tight code and easy to understand BUT if the pulse come from a PUSH-Button it can glow the LED before 10 human press as it don't provide any debounce solution. BUT if you add a 0.1-1uF in parrallel, it seems to be enough to do the job. Don't forget the pull-up resistor on the RA.4 pin. Let's say 10K as a standard valueCode:@ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _BODEN_ON
TMR0=0
led=0
WHILE TMR0<10 : WEND
LED=1
Z: GOTO Z
That should be more than enough to start ;)
Thank you for your orientation
Originally Posted by mister_e
Hello mister e
As you it can store the I number of pulses in the eeprom to continue the count if the pic is off?.
Originally Posted by Leonardo
to prevent adding any additional hardware to save count result when you remove the power, use the following
this should workCode:@ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _BODEN_ON
Data @0,0 ' set count @ 0 at programming time
led=0
Read 0, Apulse ' Read count from internal eeprom
repeat
if clkin=0 then
pause 50
apulse=apulse+1
WRITE 0,apulse ' save count in the internal EEPROM
until apulse=10
led=1
Here:
goto here
Hello mister e,
Excellent the code but like you reset the eeprom from some pin?.
One of the various method to do it
TRISB=%00000011 ' Set RB0,RB1 to input, others to output
ClrEEP var PORTB.1 ' connected between RB1 and GND
led=0 ' LED=OFF
' To Reset the value in the EEPROM, press on ClrEEP button while
' applying power. When the command is accepted, the LED will
' stay ON for 1 second
if clreep=0 then ' is ClrEEP pushbutton is pressed
write 0,0 ' Reset the pulse count in EEPROM
led=1 ' LED = ON
pause 1000 ' wait 1 sec
led=0 ' LED=OFF
endif '
repeat
if clkin=0 then
pause 50
apulse=apulse+1
until apulse=10
led=1
Here:
goto here
Hello mister e,
Thank you for their help and I hope to be able to have their support in future occasions.
Leonardo
Hello mister e,
Because uses, Here
goto here..... I don't understand it.
Hello mister e,
As I avoid the rebounds of the pulsador?.
Hello mister e,
In the following code it does add an entrance and an exit but, in RB1 and out RB6, but don't I achieve that each exit works in independent way that can happen?, like I can store the two values in the eeprom?.
TRISB=%00001111 ' Set RB0 to input, others to output
LED1 VAR PORTB.6
BOT VAR PORTB.1
Apulse1 var byte
led=0
apulse=0
led1=0
Apulse1=0
paso1:
repeat
if clkin=0 then
apulse=apulse+1
until apulse=7
led=1
paso2:
repeat
if BOT=0 then
while BOT=0 : wend
apulse1=apulse1+1
until apulse1=5
led1=1
Here:
goto here
I tried to understand but and i'm still not sure of the question. BTW i did the following, let me know if it do what you're looking for. Case not, let me know in more details or with a drawing. Sometimes it help my single brain cell to figure out the question ;)Quote:
Code:TRISB=%00001111 ' Set RB0 to input, others to output
LED1 VAR PORTB.6
BOT VAR PORTB.1
Apulse1 var byte
data @0,0,0
read 0,apulse
read 1,apulse1
led = 0
led1= 0
paso1:
repeat
if clkin=0 then
apulse=apulse+1
write 0,apulse
if BOT=0 then
while BOT=0 : wend
apulse1=apulse1+1
write 1,apulse1
until (apulse=7) or (Apulse1=5)
if apulse=7 then
led=1
led1=1
goto paso1
Hello mister e,
I sit down it it mistakes, the following code works OK, what I want is to put another entrance RB1 to count the pulses and another exit RB6 and that it stores them in the eeprom.
Thank you
the code :
led=0 ' LED=OFF
led=1 ' LED = ON
led=0 ' LED=OFF
endif '
repeat
if clkin=0 then
pause 50
apulse=apulse+1
until apulse=10
led=1
Here:
goto here
Hello mister e,
The code to count and to store the I finish pulse in the eeprom this very well, what I want is to add the same thing in RB1 and RB6 and it also stores it in the eeprom.
Thank you
led=0
repeat
if clkin=0 then
pause 50
apulse=apulse+1
until apulse=10
led=1
Here:
goto here
Hello to all,
Somebody can help me with this please.
Thank you
Hi Leonardo,
Mr E. has done a great job (As usual!) of providing code for you. But if you wired your project as shown in the drawing then this is where you are having the difficulty.
In your .bmp image you show using pull down resistors. This means your inputs are at 0vdc until the button is pressed and when you press the push button you are applying +5vdc. Your code is looking for 0v to create the activity to occur.
"if clreep=0 then ' is ClrEEP pushbutton is pressed
led=1 ' LED = ON
led=0 ' LED=OFF
endif '
repeat
if clkin=0 then
pause 50"
Turn on the internal weak pull ups and tie the other end of your push buttons to ground. To protect the PIC's inputs put 100 ohm resistors in line with the swtich and also tie MCLR to +5vdc through a 1k resistor.
This should solve your problem.
BobK
Hello mister_e
As I can modify the value of the count using the eeprom and a lcd?.
Thank you
Some suggestion
Leonardo,
i know it's really hard for you to write in english but can you provide much details. I try to understand what you say but i'm really lost.
If you want, post your question in your language, probably someone else here can give us a hand and translate to english.
I just know english(a few) and French. i'm really sorry Leonardo :(
I understand, what I want is to be able to modify the value to count by means of a keyboard 4x4 and a lcd for not having to reprogram every time that the wants to modify the I number from maximum pulses to count.
For example: to show in a lcd
Push buttom RB0 to increase the value to count
Push buttom RB1 to diminish the value to count
Push buttom RB3 enter to record the value
