serout : false byte after boot up
hello all
i have an effect now which i have some time before also...
on a pin of a pic is max232. i send some bytes with serout. all goes right.
but when i start up - the pic get the power - the first byte is sending is not correct. ever the first after boot up! after then the same routine with the same value send it right.
when i send first a byte for nothing, then the rest is good.
i've looked if i can clear the TXREG first, but my example doesn't run. i tried this (found in thread 1999)
btfss PIR1,4 ; Wait for TXREG to be empty after last byte
goto $-1 ; Not empty, wait
probaply i search at the wrong end...
thanks for any help
