Reading 5 DS18B20 Problem
I'm running into some problems that aren't making much sense to me so I'm hoping someone here can point out why this is not working the way I think it should. For some reason the raw_temp variable is not loading properly into the array. I can read each sensor fine but when I go to store the value into the array it doesn't seem to store information in the right locations.
x var byte ' Loop counter
dq var byte[9] ' 9 Byte Arrray for DS18B20
raw_temp var word[5] ' Raw Temperature
read_temps:
for x = 0 to 4
owout x,1,[$CC,$44] ' Send start temperature conversion command
low portb.5 ' Turn on transistor between rail and data pin
pause 750 ' Allow enough time to process Tconv
high portb.5 ' Turn off transistor between rail and data pin
owout x,1,[$CC,$BE] ' Send read scratch pad command
owin x,0,[STR dq\9] ' Read all 9 bytes and store them in dq array
raw_temp.Byte0[x] = dq[0] ' Isolate raw temperature from the rest
raw_temp.Byte1[x] = dq[1]
next x
goto read_temps
