max232 vs direct serial
I used a pic to talk directly to hypeterminal using debug and series resistors.
I thought I was doing the right thing by inserting a max232.
Now my code dont work!
I noticed in the the max inverts the data in as well as out.
Does the pic now get fussy, or do I need to use a different comms command?
I am using the max to achieve greater range, and eusudo multidrop.
Peter
Check your command.
You're probably using inverted RS232.
Yep, You were correct!
I checked the code and all I had to do was select True mode in Debug.
Thks for the response.
Peter
