Parsing strings received serially.
Hi guys,
I Havent used PBP for quite a while, and I'm afraid my memory is getting rusty.
I need some help with string parsing.
I get a stream of data over the serial port in the format !Vxx=yy$
Where, !V are common start bytes, xx is a 2 digit integer in decimal, followed by "=", and followed by another decimal yyy which could be either single digit, double digit OR 3 digit. And lastly, "$".
I'll need to fork off to different subd, depending on the value of xx.
What would be the best way to do this?
Thanks in advance, guys!
Re: Parsing strings received serially.
searching the forum still works
second item seems to cover it
http://www.picbasic.co.uk/forum/showthread.php?t=17632
http://www.picbasic.co.uk/forum/showthread.php?t=20953
richard
Indeed it does; somehow did not stumble across the 2nd thread; Heckler's response looks pretty much what I needed.
Thanks for the pointer.
Best Regards,
Anand Dhuru
