HELP!!! OSD Hserout problem??
Hi All!
It has been some time since I have worked with PIC's and have forgotten too much! To add to everything I am now running Windows 7 64 bit so many things are a big struggle. I was able to score the code for using an STV5730 and when I try to compile it, the compiler complains about Hserout and also the use of "[" and "]". Multiple "syntax error" and "Expected "]" or ")". Could really use some help and understanding.
Thanks, Ed
Re: HELP!!! OSD Hserout problem??
The manual tells you how HSEROUT works, that's about all I can say since you're not showing the code you're having problems with.
I forgot to upload the code!!!:mad: Sorry. You have always been one of the greatest and most knowledgeable people I have ever met. I usually try many different things first before posting any questions and it is only when I become tired and frustrated with the failures I turn to the forum and people like you. Thank you!
Ed
I feel very uncomfortable opening an attachment in that format , it could contain any amount of malware or nasty macros.
plain text please
richard
plain text please
I agree,
Ramius, copy the code and then paste it between code] [/code tags (with square brackets at either end)
Okay, sorry, thought it was too much to put in a message. i would never send an infected file and I spend a lot of time and money to make certain my machine is clean. What is confusing to me is EVERY Hserout statement shows up as a syntax error with the next line of the error saying it expected a "]" or ")"! It does not seem to like the right bracket and there are no errors for the left bracket starting at line 171. It seems to only be the Hserout statements with "CS" in them. Here is the code, thanks for looking at it!
'* Name : Overlay.BAS *
'* Author : [Grant Taylor VE3XTV / ZL1WTT] *
'* Notice : Copyright (c) 2010 *
'* : All Rights Reserved *
'* Date : Start date 30/12/2010 *
'* Version : 6.0 *
'* Notes : onging project *
' Using STV5730A as a video overlay for text information
' With a PIC16F876A or the PIC18F252 Microcontroller
' using a real time clock PCF8563
' Definitions
DEFINE OSC 20 ' 20 MHz Oscillator frequency
DEFINE HSER_RCSTA 90h ' Set receive register to receiver enabled
DEFINE HSER_TXSTA 20h ' Set transmit register to transmitter enabled
DEFINE HSER_BAUD 9600 ' Set baud rate
'Port Definition
Dpin var PORTB.0 ' I2C Data pin
Cpin var PORTB.1 ' I2C Clock pin
DA VAR PORTB.2 ' Data out
CL VAR PORTB.3 ' Clock out
EN VAR PORTB.4 ' Chip enable or chip select
'Variables
RC VAR BYTE ' Row count
CC VAR BYTE ' Character counter
LC VAR BYTE ' Line counter
wData VAR WORD ' Write data
Echo var byte ' Storage for serial character
TAB VAR BYTE ' TAB to move across a line
TP VAR WORD ' Temp variable holder
T VAR BYTE ' Time variable holder
T1 VAR BYTE ' Time variable holder
T10 VAR BYTE ' Time variable holder
NC VAR BYTE ' Number count
J VAR WORD ' Table counter variable
C VAR BYTE ' Counter variable
Co VAR BYTE ' Counter out variable
L VAR WORD ' Line counter
Sz VAR BYTE ' Text size
H VAR BYTE ' Hex number
AS VAR BYTE ' ASCII number
D VAR BYTE [28] ' ASCII Digits
CS var byte [7] ' Callsgin position array
Cx VAR BIT ' Date bit
Tx VAR BIT ' Date bit
SumA VAR BYTE ' Check output pins
SumB VAR BYTE ' Check output pins
AD0 VAR WORD ' Create ad0 to store result
AD1 VAR WORD ' Create ad1 to store result
X VAR BIT ' Callsign set bit
Init:
TRISA = %000011 ' Set as both
ADCON1 = %00000010 ' Set PORTA analog and LEFT justify result
TRISB = %00000011 ' Set as both
TRISC = %11111111 ' Set as both
H=$30 : Tx=1 : Cx=0 : X=0
' STV5730A initialize
initSTV:
High Cl :High DA :High EN ' Start up data
Pause 250 ' 250ms wait
wData=$3000 : GoSub Send ' Send 3000 in Hex
wData=$00DB : GoSub Send ' Send 00DB in Hex
wData=$1000 : GoSub Send ' Send 1000 in Hex
wData=$00CC : GoSub Send ' Init registers (point to register 12)
wData=$1000 : GoSub Send ' Zoom
wData=$1000 : GoSub Send ' Colour
wData=$1ACE : GoSub Send ' Control set to NTSC
wData=$15A1 : GoSub Send ' Position
wData=$183C : GoSub Send ' Mode
wData=$00C0 : GoSub Send ' Set row attributes
For RC=0 TO 10 ' Rows from 0 to 10
wData=$10C4 : GoSub Send
Next RC
CC=0: LC=0 ' Set line and row to 0
GOSUB CLS ' Clear video screen
PAUSE 250
GOTO com_set
CLS:
wData=lc*256+CC ' Line and row data
GoSub Send ' Send data to STV5730A
wData=$1F0B ' Set character to " "
CC=CC+1
IF CC>=28 Then ' Max character count of 28
CC=0
lc=LC+1
EndIF
IF Lc=11 THEN ' Max line count of 11
GoTo CLS
Send: ' Send data to STV5730A
PAUSEUS 250 ' Deylay of 250 uS
Low EN ' Set chip select low
GoSub Serial ' Send 16 bit word
High EN ' Set chip select pin high
High Cl ' Set clock pin high
High DA ' Set data pin high
Serial: ' Serial out routine
DA=wData.15 ' Bring Do pin high or low, depending upon bit
PULSOUT CL,1 ' Bring Clock line high and then low
DA=wData.14 ' Same as above
PULSOUT CL,1 ' Same as above
DA=wData.13
PULSOUT CL,1
DA=wData.12
PULSOUT CL,1
DA=wData.11
PULSOUT CL,1
DA=wData.10
PULSOUT CL,1
DA=wData.9
PULSOUT CL,1
DA=wData.8
PULSOUT CL,1
DA=wData.7
PULSOUT CL,1
DA=wData.6
PULSOUT CL,1
DA=wData.5
PULSOUT CL,1
DA=wData.4
PULSOUT CL,1
DA=wData.3
PULSOUT CL,1
DA=wData.2
PULSOUT CL,1
DA=wData.1
PULSOUT CL,1
DA=wData.0
PULSOUT CL,1
PC_time: ' Time comport
T=0
I2CREAD Dpin,Cpin,$A3,$02,[T]
GOSUB Tcon
CS[0]=T
I2CREAD Dpin,Cpin,$A3,$03,[T]
GOSUB Tcon
CS[1]=T
I2CREAD Dpin,Cpin,$A3,$04,[T]
T=T&$3F
GOSUB Tcon
CS[2]=T
hserout ["Time in h,m,s"]
GOSUB linefeed ' Send text followed by carriage return and linefeed
GOSUB linefeed ' Carriage return and linefeed
Hserout [DEC CS[2],":",DEC CS[1],".",DEC CS[0]] ' Send text followed by carriage return and linefeed
GOSUB linefeed
PC_date: ' Date comport
I2CREAD Dpin,Cpin,$A3,$05,[T]
T=T&$3F
GOSUB Tcon
CS[3]=T
I2CREAD Dpin,Cpin,$A3,$06,[T]
T=T&$07
GOSUB Tcon
CS[4]=T
I2CREAD Dpin,Cpin,$A3,$07,[T]
T=T&$1F
GOSUB Tcon
CS[5]=T
I2CREAD Dpin,Cpin,$A3,$08,[T]
GOSUB Tcon
CS[6]=T
hserout ["Date in d,m,y"] ' Send text followed by carriage return and linefeed
GOSUB linefeed
IF CS[4]=0 THEN hserout ["Sunday",13,10]
IF CS[4]=1 THEN hserout ["Monday",13,10]
IF CS[4]=2 THEN hserout ["Tuesday",13,10]
IF CS[4]=3 THEN hserout ["Wednesday",13,10]
IF CS[4]=4 THEN hserout ["Thursday",13,10]
IF CS[4]=5 THEN hserout ["Friday",13,10]
IF CS[4]=6 THEN hserout ["Saturday",13,10]
Hserout [DEC CS[3],"/",DEC CS[5],"/20",DEC CS[6]] ' Send text followed by carriage return and linefeed
GOSUB linefeed
Tcon:
T=T&$7F
T1 =($0F&T)
T10=(T/$10)*10
T=T10+T1
Set_time:
T10=(T10-H)*$10
T1 =T1-H
Co=T10+T1
vcon:
CS[1]=T DIG 0 ' Read the position of digit 2
CS[0]=T DIG 1 ' Read the position of digit 1
v_time: ' Display time via the video
J=J+1
T=T&$3F
SumB=t
IF Cx=1 AND SumA<>SumB THEN GOSUB v_date
IF Tx=1 AND J=250 THEN GOSUB Temp
wData=$700
GOSUB Send
T=T&$3F
GOSUB Tcon
GOSUB vcon
for C=0 to 2 ' Read data out to STV5730A
LOOKUP2 C,[CS[0],CS[1],$26],Co
wData=$1300+Co
gosub Send
NEXT C
GOSUB Tcon
GOSUB vcon
FOR C=0 to 2 ' Read data out to STV5730A
wData=$1300+Co
GOSUB Send
NEXT C
GOSUB Tcon
GOSUB vcon
FOR C=0 to 1 ' Read data out to STV5730A
LOOKUP2 C,[CS[0],CS[1]],Co
wData=$1300+Co
gosub Send
NEXT C
Hserin 40,v_time,[echo]
IF ECHO=27 THEN
GOSUB linefeed
Hserout ["Exit"]
GOSUB linefeed
GOSUB linefeed
GOSUB CLS
CC=0: Lc=0 : L=0 : Cx=0 : Tx=0
GOTO v_time:
v_date: ' Display date via the video
wData=$800
gosub Send
T=T&$3F
SumA=t
GOSUB Tcon
GOSUB vcon
LOOKUP2 C,[CS[0],CS[1],$28],Co
wData=$1300+Co
GOSUB Send
next C
T=T&$1F
GOSUB Tcon
GOSUB vcon
wData=$1300+Co
GOSUB Send
next C
GOSUB Tcon
GOSUB vcon
FOR C=0 to 3 ' Read data out to STV5730A
LOOKUP2 C,[2,0,CS[0],CS[1]],Co
wData=$1300+Co
GOSUB Send
NEXT C
Tempcom: ' Read temperture
GOSUB Tmp1
IF D[3]=$0B THEN
D[3]=32
D[3]=D[3]+H
IF D[2]<$0A THEN D[2]=D[2]+H
IF D[2]=$0B THEN D[2]=32
IF D[2]=$0A THEN D[2]=45
Hserout ["temp 1 ",D[2],D[3],D[4]+H,"C"]
GOSUB linefeed
GOSUB Tmp2
IF D[3]=$0B THEN
D[3]=32
D[3]=D[3]+H
Hserout ["temp 2 ",D[2],D[3],D[4]+H,"C"]
GOSUB linefeed
GOSUB linefeed
Temp: ' Display Temperture via the video
wData=$70C
gosub Send
for C=0 to 10 ' Read data out to STV5730A
LOOKUP2 C,[$1F,$2E,$36,$39,$2E,$3B,$2A,$3D,$3E,$3B,$2E],Co
wData=$1300+Co
gosub Send
next C
GOSUB Tmp1
wData=$80C
gosub Send
for C=0 to 5 ' Read data out to STV5730A
LOOKUP2 C,[$1,$0B,D[2],D[3],D[4],$0E],Co
wData=$1300+Co
gosub Send
next C
GOSUB Tmp2
wData=$814
gosub Send
LOOKUP2 C,[$2,$0B,D[2],D[3],D[4],$0E],Co
wData=$1300+Co
gosub Send
next C
Tx=1
J=0
Tmp1:
ADCIN 0,AD0 ' Read ADC one
Tp=AD0/64
GOSUB Temp_C
Tmp2:
ADCIN 1,AD1 ' Read ADC two
Tp=AD1/64
GOSUB Temp_C
Temp_C:
IF Tp>=559 THEN
J=(Tp-559)*100 ' Calulate out temperture in +
C=J/205
J=(Tp-354)*100 ' Calulate out temperture in -
C=100-(J/205)
GOSUB AtoDcaL
AtoDcaL:
D[4]=C DIG 0 ' Read the position of digit 5
D[3]=C DIG 1 ' Read the position of digit 4
D[2]=C DIG 2 ' Read the position of digit 3
D[1]=C DIG 3 ' Read the position of digit 2
D[0]=C DIG 4 ' Read the position of digit 1
IF D[0]+D[1]+D[2]+D[3]=0 THEN D[3]=$0B ' Add space in (Hex B)
IF D[0]+D[1]+D[2]=0 THEN D[2]=$0B
IF D[0]+D[1]=0 THEN D[1]=$0B
IF D[0]=0 THEN D[0]=$0B
' Comport setup
com_set:
wData=0 : Sz=0
L=0 : TAB=0 : J=0
CC=0: Lc=0 : Cx=0 : Tx=0
hserout ["Video overlay"] ' Send text followed by carriage return and linefeed
GOSUB linefeed
Hserout ["by Grant VE3XTV"] ' Send text followed by carriage return and linefeed
com_start: ' Comport start up
IF Sz=0 THEN
wData=$00CC
GoSub Send
wData=$1000
GoSub Send
IF Sz=1 THEN
wData=$00CC
GoSub Send
wData=$1555
GoSub Send
IF Sz=2 THEN
wData=$00CC
GoSub Send
wData=$1AAA
GoSub Send
IF Sz=3 THEN
wData=$00CC
GoSub Send
wData=$1FFF
GoSub Send
com:
FOR NC=1 TO 10
Hserin 4000,com_start,[echo] ' Get a echo from serial port
IF ECHO=13 THEN
GOTO getinfo
GOTO com
IF NC=1 THEN D[0]=ECHO ' Store last 10 ASCII digits
IF NC=2 THEN D[1]=ECHO
IF NC=3 THEN D[2]=ECHO
IF NC=4 THEN D[3]=ECHO
IF NC=5 THEN D[4]=ECHO
IF NC=6 THEN D[5]=ECHO
IF NC=7 THEN D[6]=ECHO
IF NC=8 THEN D[7]=ECHO
IF NC=9 THEN D[8]=ECHO
IF NC=10 THEN D[9]=ECHO
Hserout [echo] ' Send echo out serial port
NEXT NC
Goto com
getinfo:
GOSUB linefeed
IF D[0]=67 AND D[1]=76 AND D[2]=83 THEN ' CLS Clear screen
GOSUB CLS
GOSUB linefeed
Hserout ["Clear screen"]
GOSUB linefeed
GOSUB linefeed
GOTO com
IF D[0]=67 THEN ' C?????? set callsgin
CS[0]=D[1] : CS[1]=D[2] : CS[2]=D[3] : CS[3]=D[4] : CS[4]=D[5] : CS[5]=D[6]
GOSUB linefeed
Hserout ["Set to ",CS[0],CS[1],CS[2],CS[3],CS[4],CS[5]]
GOSUB linefeed
GOSUB linefeed
GOTO com
IF D[0]=68 AND D[1]=67 THEN ' DC display callsgin
GOSUB DC
GOSUB linefeed
Hserout ["Display callsgin"]
GOSUB linefeed
GOSUB linefeed
GOTO com
IF D[0]=84 AND D[1]=89 AND D[2]=80 AND D[3]=69 THEN ' TYPE keyboard mode
GOSUB linefeed
Hserout ["Keyboard mode"]
GOSUB linefeed
GOSUB linefeed
GOTO TYPE
ENDIF ' Font size=1
IF D[0]=72 AND D[1]=49 THEN
Sz=0
GOSUB linefeed
Hserout ["Font size=1"]
GOSUB linefeed
GOSUB linefeed
IF D[0]=72 AND D[1]=50 THEN
Sz=1
GOSUB linefeed
Hserout ["Font size=2"] ' Font size=2
GOSUB linefeed
GOSUB linefeed
IF D[0]=72 AND D[1]=51 THEN
Sz=2
GOSUB linefeed
Hserout ["Font size=3"] ' Font size=3
GOSUB linefeed
GOSUB linefeed
IF D[0]=72 AND D[1]=52 THEN
Sz=3
GOSUB linefeed
Hserout ["Font size=4"] ' Font size=4
GOSUB linefeed
GOSUB linefeed
IF D[0]=82 AND D[1]=68 THEN ' 82 and 68 is RD to read callsgin
GOSUB linefeed
GOSUB Rdata
IF D[0]=87 AND D[1]=68 THEN ' 82 and 68 WD write data
GOSUB linefeed
GOSUB Memstore
Hserout ["Writing data"]
GOSUB linefeed
GOSUB linefeed
GOTO com
IF D[0]=84 AND D[1]=73 AND D[2]=77 AND D[3]=69 THEN ' TIME display time on PC
GOSUB linefeed
Hserout ["Time is"]
GOSUB linefeed
GOSUB linefeed
GOSUB PC_time
GOTO com
IF D[0]=68 AND D[1]=65 AND D[2]=84 AND D[3]=69 THEN ' DATE display time on PC
GOSUB linefeed
Hserout ["Date is"]
GOSUB linefeed
GOSUB linefeed
GOSUB PC_date
GOTO com
IF D[0]=83 AND D[1]=84 THEN ' ST Set time format "hh:mm" enter to set
T10=D[2] : T1=D[3]
GOSUB Set_time
I2CWRITE Dpin,Cpin,$A2,$04,[Co]
T10=D[5] : T1=D[6]
GOSUB Set_time
I2CWRITE Dpin,Cpin,$A2,$03,[Co]
GOSUB linefeed
Hserout [D[2],D[3],":",D[5],D[6]]
GOSUB linefeed
GOSUB linefeed
GOTO com
IF D[0]=83 AND D[1]=83 THEN ' SS Set seconds format "ss" enter to set
GOSUB linefeed
Hserout [D[2],D[3]," seconds"]
GOSUB linefeed
GOSUB linefeed
T10=D[2] : T1=D[3]
GOSUB Set_time
I2CWRITE Dpin,Cpin,$A2,$02,[Co]
GOTO com
IF D[0]=83 AND D[1]=68 THEN ' SD Set date format "dd/MM/YY" enter to set
T10=D[2] : T1=D[3]
GOSUB Set_time
I2CWRITE Dpin,Cpin,$A2,$05,[Co]
T10=D[5] : T1=D[6]
GOSUB Set_time
I2CWRITE Dpin,Cpin,$A2,$07,[Co]
T10=D[8] : T1=D[9]
GOSUB Set_time
I2CWRITE Dpin,Cpin,$A2,$08,[Co]
GOSUB linefeed
Hserout [D[2],D[3],"/",D[5],D[6],"/",D[8],D[9]]
GOSUB linefeed
GOSUB linefeed
GOTO com
IF D[0]=83 AND D[1]=87 THEN ' SW Set week day format "w" enter to set
GOSUB linefeed
Hserout [D[2]," day of the week"]
GOSUB linefeed
GOSUB linefeed
T10=0 : T1=D[2]
GOSUB Set_time
I2CWRITE Dpin,Cpin,$A2,$06,[Co]
GOTO com
IF D[0]=68 AND D[1]=84 AND D[2]<>77 AND D[3]<>80 THEN ' DT Display time via video
J=0
GOSUB linefeed
Hserout ["Display time"]
GOSUB linefeed
GOSUB linefeed
GOSUB v_time
IF D[0]=68 AND D[1]=68 THEN ' DD Display date via video
Cx=1
GOSUB linefeed
Hserout ["Display date"]
GOSUB linefeed
GOSUB linefeed
GOSUB v_date
IF D[0]=68 AND D[1]=84 AND D[2]=77 AND D[3]=80 THEN ' DTMP display temperature via video
Tx=1
GOSUB linefeed
Hserout ["Display temperature"]
GOSUB linefeed
GOSUB linefeed
GOSUB temp
IF D[0]=84 AND D[1]=69 AND D[2]=77 AND D[3]=80 THEN ' TEMP display temperature
GOSUB linefeed
Hserout ["Temperature is"]
GOSUB linefeed
GOSUB linefeed
GOSUB Tempcom
GOTO com
IF D[0]=72 AND D[1]=69 AND D[2]=76 AND D[3]=80 THEN ' HELP infomation
GOSUB linefeed
Hserout ["CLS clear display"]
GOSUB linefeed
Hserout ["DC display callsgin"]
GOSUB linefeed
Hserout ["DTMP display temperature"]
GOSUB linefeed
Hserout ["DT display time"]
GOSUB linefeed
Hserout ["DD display date"]
GOSUB linefeed
Hserout ["H1,H2,H3,H4 font sizes 1x up to 4x"]
GOSUB linefeed
Hserout ["TYPE keyboard text mode, video overlay"]
GOSUB linefeed
Hserout ["TIME display time on PC"]
GOSUB linefeed
Hserout ["DATE display date on PC"]
GOSUB linefeed
Hserout ["TEMP display temperature on PC"]
GOSUB linefeed
GOSUB linefeed
Hserout ["****** Setup information ******"]
GOSUB linefeed
Hserout ["RD read data"]
GOSUB linefeed
Hserout ["WD write data"]
GOSUB linefeed
Hserout ["C?????? set callsgin"]
GOSUB linefeed
Hserout ["SS set seconds format 'ss'"]
GOSUB linefeed
Hserout ["ST set time format 'hh:mm'"]
GOSUB linefeed
Hserout ["SD set date format 'dd/MM/YY'"]
GOSUB linefeed
Hserout ["SW set week day format 'w'"]
GOSUB linefeed
GOSUB linefeed
GOTO com
GOTO com_start
Rdata:
GOSUB linefeed
Hserout ["Font size=",DEC Sz+1]
GOSUB linefeed
GOSUB Memread
GOSUB linefeed
Hserout ["Callsgin=",CS[0],CS[1],CS[2],CS[3],CS[4],CS[5]] ' Send message
GOSUB linefeed
GOSUB linefeed
GOSUB linefeed
rETURN
Memstore: ' Store Callsign
FOR C=0 TO 5
WRITE C,CS[C]
NEXT C
Memread: ' Read Callsign
FOR C=0 TO 5
READ C,CS[C]
NEXT C
DCLS: ' Clear the screen set to ' '
FOR C=0 TO 27
D[C]=32
NEXT C
com1:
GOSUB DCLS
FOR NC=1 TO 28
Hserin 4000,com1,[echo] ' Get a echo from serial port
IF ECHO=13 THEN GOTO TYPE1
IF ECHO=9 THEN GOSUB Tabspace
IF ECHO=92 THEN
GOSUB CLS : CC=0: Lc=0 : L=0
GOTO com1 : ENDIF
IF ECHO=8 THEN
GOSUB Backspace : ENDIF
IF ECHO=27 THEN
GOSUB linefeed
Hserout ["Exit"]
GOSUB linefeed
GOSUB linefeed
GOTO com : ENDIF
IF NC=1 THEN D[0]=ECHO ' Store last 28 ASCII digits
IF NC=11 THEN D[10]=ECHO
IF NC=12 THEN D[11]=ECHO
IF NC=13 THEN D[12]=ECHO
IF NC=14 THEN D[13]=ECHO
IF NC=15 THEN D[14]=ECHO
IF NC=16 THEN D[15]=ECHO
IF NC=17 THEN D[16]=ECHO
IF NC=18 THEN D[17]=ECHO
IF NC=19 THEN D[18]=ECHO
IF NC=20 THEN D[19]=ECHO
IF NC=21 THEN D[20]=ECHO
IF NC=22 THEN D[21]=ECHO
IF NC=23 THEN D[22]=ECHO
IF NC=24 THEN D[23]=ECHO
IF NC=25 THEN D[24]=ECHO
IF NC=26 THEN D[25]=ECHO
IF NC=27 THEN D[26]=ECHO
IF NC=28 THEN D[27]=ECHO
NEXT NC
Goto com1
Tabspace:
TAB=TAB+7
FOR C=1 TO 7
Echo=32
Hserout [echo]
NEXT C
Backspace:
NC=NC-1
IF NC<=1 THEN NC=1
LOOKUP2 Nc,[0,D[0],D[1],D[2],D[3],D[4],D[5],D[6],D[7],D[8],D[9],D[10],D[11],D[12],D[13],D[14],D[15],D[16],D[17],D[18],D[19],D[20],D[21],D[22],D[23],D[24],D[25],D[26],D[27]],Co
Co=Echo
Hserout [echo]
Hserin 2000,com_start,[echo] ' Get a echo from serial port
IF ECHO=8 THEN GOTO Backspace
DC: ' Display Callsgin
GOSUB DCLS
GOSUB Memread
FOR C=0 TO 5
AS=CS[C]
GOSUB Convert
D[C]=AS
NEXT C
X=1
GOSUB Display
X=0
TYPE: ' Conversion for the video overlay
GOSUB linefeed
GOTO com1
TYPE1:
GOSUB linefeed
AS=D[0]
GOSUB Convert
D[0]=AS
AS=D[1]
GOSUB Convert
D[1]=AS
AS=D[2]
GOSUB Convert
D[2]=AS
AS=D[3]
GOSUB Convert
D[3]=AS
AS=D[4]
GOSUB Convert
D[4]=AS
AS=D[5]
GOSUB Convert
D[5]=AS
AS=D[6]
GOSUB Convert
D[6]=AS
AS=D[7]
GOSUB Convert
D[7]=AS
AS=D[8]
GOSUB Convert
D[8]=AS
AS=D[9]
GOSUB Convert
D[9]=AS
AS=D[10]
GOSUB Convert
D[10]=AS
AS=D[11]
GOSUB Convert
D[11]=AS
AS=D[12]
GOSUB Convert
D[12]=AS
AS=D[13]
GOSUB Convert
D[13]=AS
AS=D[14]
GOSUB Convert
D[14]=AS
AS=D[15]
GOSUB Convert
D[15]=AS
AS=D[16]
GOSUB Convert
D[16]=AS
AS=D[17]
GOSUB Convert
D[17]=AS
AS=D[18]
GOSUB Convert
D[18]=AS
AS=D[19]
GOSUB Convert
D[19]=AS
AS=D[20]
GOSUB Convert
D[20]=AS
AS=D[21]
GOSUB Convert
D[21]=AS
AS=D[22]
GOSUB Convert
D[22]=AS
AS=D[23]
GOSUB Convert
D[23]=AS
AS=D[24]
GOSUB Convert
D[24]=AS
AS=D[25]
GOSUB Convert
D[25]=AS
AS=D[26]
GOSUB Convert
D[26]=AS
AS=D[27]
GOSUB Convert
D[27]=AS
GOSUB Display
GOTO com1
Convert: ' Convert from ACSII to TROM data of the STV5730A
IF AS>=48 AND AS<=57 THEN
AS=AS-48
IF AS>=65 AND AS<=90 THEN
AS=AS-53
IF AS>=97 AND AS<=122 THEN
AS=AS-55
IF AS>=46 AND AS<=47 THEN
AS=AS-7
IF AS=45 THEN
AS=$A
IF AS=32 THEN
AS=$B
IF AS=34 THEN
AS=$6F
IF AS=58 THEN
AS=$26
IF AS=39 THEN
AS=$29
IF AS=42 THEN
AS=$5F
IF AS=43 THEN
AS=$5E
IF AS=63 THEN
AS=$70
IF AS=60 THEN
AS=$7B
IF AS=62 THEN
AS=$7A
IF AS=94 THEN
AS=$7C
IF AS=124 THEN
AS=$7D
IF AS=35 THEN
AS=$6E
IF AS=36 THEN
AS=$71
IF AS=37 THEN
AS=$79
IF AS=64 THEN
AS=$45
IF AS=61 THEN
AS=$78
AS=$B
Display: ' Font size 1 to 4
IF Sz=0 THEN GOSUB Size_1
IF Sz=1 THEN GOSUB Size_2
IF Sz=2 THEN GOSUB Size_3
IF Sz=3 THEN GOSUB Size_4
Size_1:
wData=L+tab
gosub Send
IF X=0 THEN
J=27
J=5
FOR C=0 TO J
LOOKUP2 c,[D[0],D[1],D[2],D[3],D[4],D[5],D[6],D[7],D[8],D[9],D[10],D[11],D[12],D[13],D[14],D[15],D[16],D[17],D[18],D[19],D[20],D[21],D[22],D[23],D[24],D[25],D[26],D[27]],Co
wData=$1300+Co
gosub Send
NEXT C
L=L+$100
IF L=$B00 THEN L=0
TAB=0
Size_2:
wData=L+tab
gosub Send
FOR C=0 TO 13
LOOKUP2 c,[D[0],D[1],D[2],D[3],D[4],D[5],D[6],D[7],D[8],D[9],D[10],D[11],D[12],D[13]],Co
wData=$1300+Co
gosub Send
NEXT C
L=L+$100
IF L=$600 THEN L=0
TAB=0
Size_3:
wData=L+tab
gosub Send
FOR C=0 TO 9
LOOKUP2 c,[D[0],D[1],D[2],D[3],D[4],D[5],D[6],D[7],D[8],D[9]],Co
wData=$1300+Co
gosub Send
NEXT C
L=L+$100
IF L=$400 THEN L=0
TAB=0
Size_4:
wData=L+tab
gosub Send
FOR C=0 TO 6
LOOKUP2 c,[D[0],D[1],D[2],D[3],D[4],D[5],D[6]],Co
wData=$1300+Co
gosub Send
NEXT C
L=L+$100
IF L=$300 THEN L=0
TAB=0
linefeed:
Hserout [13,10]
that's why code tags help and are reccomended .
if its not too late maybe you can edit it and put them in
ps it won't compile because its too big to fit in your chip.
Hi Ed,
Of course you're not sending an infected file - intentionally - but people are being careful, just like you and that's a good thing. It's not to much code to post but you really should use the proper code tags so it ends up in a scrollable window and doesn't loose indentation etc. See here: https://www.bbcode.org/examples/?id=15 for instructions on how to use it.
Back to your problem then....
I tried compiling your code for the 18F452 and it compiled without any errors. I also tried the mentioned 16F876A but then I get a couple of error from the assembler (Argument out of range 8207 not between 0 and 8191) however selecting another random 16F series device (like the 16F1829) makes it compile without any errors.
For which device are you trying to compile?
What version of PBP are using?
What version of MPASM are you using?
Hi Henrik!
Thank you! Ultimately I would like to use the 18F1320. I just tried to compile with the 16F876A as that was what Grant said was the PIC the code was written for. I am using the latest PBP 3.1 and MPASM 8.92, Windows 7 64 bit.
Thanks, Ed
But when I compile for the 16F876A I don't get the same errors you're reporting.
I just tried again, on a machine with PBP 3.0.8.4 and MPASM 5.61 (from MPLABX 2.35) and for the 16F876A I get the same errors I reported earlier - I do not get any of the errors you report. The errors I *do* get is most likely because the code is too big to fit in the 876A - as Richard points out. Where your Syntax Errors is coming from I have no idea.
The compiled code size for an 18F series device is 15242 bytes and the 18F1320 is an 8k device so it won't fit as is.
I'd probably update MPLAB to a newer version, you'll need it to use the new devices added in PBP3.1
most likely code ed is compiling != code posted.
is this a deliberate ploy to fill unused code space ?
