Re: Two questions / errors
Line numbers are a part of the IDE so it depends on which IDE you're using. Going by your second question I believe you're using MicroCodeStudio but I'm not sure it has that feature though you can see which line the cursor is on at the bottom of the screen. I don't have MCS on this machine so I can't be of more assistance than that I'm afraid.
It sounds as if you're hitting the ICD Compile button instead of the normal Compile button. Make sure you're clicking the correct one...
It does. From IDE main menu select 'View | Editor Options... | General tab' and check 'Show line numbers in left gutter'
Thank you and I finally found the line numbers! :D Now if I can only get the ICD to function correctly!
Ed
