How to use a potentiometer resistor to control speed of motor fan manually?Thanks
Hi,everybody...i am just a beginner to use Pic...and the software that i use to compile is PicBasic Pro
Thus, i would like to know any ideas to use potentiometer resistor of 10k ohm to control the speed of motor fan manually...like i increase the voltage of potentiometer,the fan will run faster...and the opposite.
In pic Basic code,i try to add ADCIN and PWM command into it. ADCIN command is read adc values and store in a variable. Then i write a PWM command to control speed.
Any ideas, or any Pic Basic Pro source codes can help me...thanks :)
