Help, problems first time with 18F452 PIC
Hello, I just recieved my MELABS seriel programmer and PIC Basic Pro. I tried doing the initial 'Blink' program with no success. Let me begin by telling my process for programming in case I am doing something wrong.
1) I first select the right PIC and write my code in MicroCode Studio, my program is:
DEFINE OSC 10
loop: High PORTB.1 ' Turn on LED connected to PORTB.1
Pause 200 ' Delay for .2 seconds
Low PORTB.1 ' Turn off LED connected to PORTB.1
Goto loop ' Go back to loop and blink LED forever
As you can see I am operating at 10 Mhz with a 10 Mhz ceramic resonator with built in capacitors.
2) Next, I compile to get the Hex file for the program. I open Melabs Programmer, select the correct PIC, load my Hex file, Erase the PIC, check for blank, then Program the PIC. I then turn off the seriel programmer and remove the PIC, followed by placing it in my circuit.
My circuit consists of a 5 Volt supply, a 10 uf and .1 uf decoupling capacitors across the +5 and ground, and the ceramic 3 pin resonator (with built in caps) connected to the 2 resonator pins and the ground pin tied to ground. Portb.1 is tied to a 1k resistor and led in series.
Results:
When the power is turned on, Portb.1 outputs 5 volts for about 1 second, shuts off and then nothing else happens. I have tried troubleshooting this problem with no success whatsoever.
Is there anything wrong with my PicBasic Pro code that I am not seeing here?
Thanks for any help.
search for a post by melanie on config
Hi there,
As far as I remember Melanie did give a full reference on the @config issues. I do it in a different way. I edited the 18F452.inc file in the pbp folder and change the XT_OSC to HS_PLL. Actually I run almost all my 18F452 @40MHz. That gives me fastest running code however practical serial communication is limited to 9.6K. Higher rates yield high baud rate error. BTW a simple define "DEFINE osc 40" will make your timing correct under PBP. Keep exploring.
Sougata
