i may forgot to initialize...
dear bruce,
i failed to initialized the WORD but in my program. also my bad, this is my code.
init:
decideInterval var WORD
TIMEINTERVAL con 600
decideInterval = 0
decideInterval = decideInterval + 1
IF decideInterval = TIMEINTERVAL then
decideInterval = 0 ;resets the decideInteval
(a command output to LCD display)
GOTO MAIN
i verified it that it enters the IF/THEN statement with the decideInterval = 11 or other pseudo-randomly values. sorry for the incomplete info a while ago. but this post seems to be complete now.
thanks
regards,
yettie
i consider it as BUG still...
bruce,
to make things clear. i've written it in a program to have a 31.25ms timer at a prescale of 1:8,yielding a 250ms to overflow TIMER1. i verified it in a oscilloscope that it is accurate.
define debug_reg porta 'nevermind my serial LCD display debugger
define debug_bit 0
define debug_baud 2400
define debug_mode 1
define inthand checkNow
define OSC 8
CMCON=7
time var word
timeL var time.byte0
timeH var time.byte1
decideTimeInterval var word
setup:
debug 12,"Starting",10,13," Program",4
pause 2000
intcon = %11000000 ;setting up gie and peie bits
time = 3036 ;calibrated to have 31.25ms scale
tmr1L = timeL ;65536 - time (preload value)
tmr1H = timeH
flag = 0
PIR1.0 = 0
PIE1.0 = 1
T1CON = %110001 ;setting up to 1:8 prescale
;31.25ms x 8 = 250ms/count
if flag = 4 then ;(250ms x 4 = 1s) second ticker
flag = 0
decideTimeInterval = decideTimeInterval + 1
gosub updateTime
if decideTimeInterval = TIMEINTERVAL then ;this one is the notorious routine. it's just a reset condition.
decideTimeInterval = 0 ;It resets unexpectedly. In contrast to this,
endif ;changing the decideTimeInterval to BYTE and of course
;TIMEINTERVAL <= 255 will function properly
updateTime:
DEBUG "Time:",#decideTimeInterVal
;interrupt handler
@checkNow
pie1.0 = 0
flag = flag + 1
time = 3036
toggle = portb.3 ;my monitor to oscilloscope, it accurately toggles at 250ms cycle
TMR1L = timeL
TMR1H = timeH
PIR1.0 = 0
PIE1.0 = 1
resume
i hope now that everything clear for you now. the decideTimeInterval counter now increments every second avoiding fast incrementing, like you said.
any ideas?
thanks and I appreciate very much
regards,
yettie
