Hi, I would like to know which commands I should use to read and write the ds1996 memory. I know how to read the serial number, but don't know the rest. I'm new to this and will appretiate any help.
Does de ds1996 works with 1-wire?
Yes, it uses 1-wire.
go to the maxim site download the DS2433 eeprom datasheet a write / read example (using 1-wire) is present in it.
Check the read.write and copy scratchpad sections
I think I now know how to read and write to the DS1996 tag, but I have a different problem now. I can't read the serial number. It read the DS1990 and DS1994 tag serial number fine, but doesn't read the DS1996. Is there something different I have to do to the DS1996 tag to read the serial number?
Hi Peder,
My name is Bosse from Norway.
Have also problem Writing/Reading to DS1996 Memory - Have you found out how to use the whole memory in DS1996 for storing and retrieving data.
Very greatful for all help I can get - using PicBasic Pro
Bosse
