Unwanted pulse on PortC.1 on 16F876
I have scanned the posts for similar problems to the one I am detailling below but to be honest I'm not exactly sure what to look for.
I am using a 16F876 (4Mhz) to drive two DS1267 digital pots on Port C. The two RST (chip select lines) of the Ds1267's are connected to RC0 and RC1 respectively. The clock (CLK) and data (DQ) lines are paralleled and connect to RC2 and RC3.
The program selects the appropriate DS1267 by sending either RC0 or RC1 high then uses SHIFTOUT to write the data.
When RC0 goes high a pulse appears on RC1 that is sufficiently long enough to confuse the hell out of the other DS1267. However, the reverse is not true, i.e. when RC1 goes high no pulse appears on RC0 so it works fine.
This extra pulse is driving me nuts!
I suspect it has something to do with Timer1 or even CCP2 that are multiplexed on these two ports. I must admit that even after reading the datasheet for the 876 I am not proficient enough to understand how to ensure these functions are off. Of course there's a very real chance it has nothing to do with these functions and I'm barking up the wrong proverbial tree.
There must be someone who knows where these extra pulses come from and how I can stop them.
Thanks.
Pinouts and Code for pulse problem
Hi Acetronics,
Does this help?
Pinout:
1 ]
6 ]RC0 (pin11) >>>> DS1267(1) RST (pin5)
F ]RC1 (pin12) >>>> DS1267(2) RST (pin5)
8 ]RC2 (pin13) >>>> DS1267(both) CLK (pin6)
7 ]RC3 (pin14) >>>> DS1267(both) DQ (pin8)
6 ]
Code
DEFINE SHIFT_PAUSEUS 100
DEFINE CHAR_PACING 100 'add 100 uSec extra stop bit
rst1 var PORTC.0 'DS1267 POT1 chip select port
rst2 var PORTC.1 'DS1267 POT2 chip select port
clk var PORTC.2 'DS1267 POTS clock port
dq var PORTC.3 'DS1267 POTS Data port
ampwiper var byte 'DS1267 pot wiper positions
sparewiper var byte
pwwiper var byte
freqwiper var byte
OUTPUT rst1: OUTPUT rst2: OUTPUT clk: OUTPUT dq
high rst1
SHIFTOUT dq,clk,1,[%0\1,ampwiper,sparewiper] 'Code required to write to DS1267
low rst1
The last three lines seem to put the unwanted pulse on PORTC.1
However,
high rst2
SHIFTOUT dq,clk,1,[%0\1,freqwiper,pwwiper]
low rst2
Does not put a pulse on PORTC.0
Cheers
Muttley
