SEROUT2 and SERIN2 commands
Hi, I have some quetions about the use of serin2 and serout2 commands:
1). I have circuit with master-slave connection (both are PIC16F84A),
The slave will send characters in string format just like:
SEROUT2, So, 396,("13201150")
And the master will receive that characters with SERIN2, such:
SERIN2, Si, 396,[wait ("13201150"), B0)
Then I want to display the value of B0 (should is "13201150") with
command:
LCDOUT $fe,1
LCDOUT #B0
But it is failed. The result on display is just like the ASCII value.
Do i make some mistakes here?
2). I have find out that the SEROUT2 and SERIN2 command can send and
receive one character only.If in slave I use command:
SEROUT2, So, 396,("a")
Then in master I use command:
SERIN2, Si, 396,[wait ("a"), B0]
And on LCD I use:
LCDOUT $fe,1
LCDOUT B0 ------->>> WITHOUT #
Then it does work well. Can someone explain it?
3) I want an example of the using of WAITSTR ArrayVar command....
4) Can the master received some characters only?Such us: if I want
that the master received the value of characters from "a" to "j" only,
so while the slave send character that out of range the value, then it
will be denied, and viceversa.what the SERIN2 command in master will
gonna be?
Thanks guys....
