Re: Pullup confusion 12c508a
That chip is so old I am afraid to answer.
Looking at page 17 of the data sheet.
It looks like you would set the option register bit 6 to 0
OPTION.6 = 0 'sets weak pullups on gp0,gp1 and gp3
Add: Read this also
http://melabs.com/support/12-bit.htm
Hi Michael,
The PIC12C508A doesn't have a PORTB so your WPUB statement will obviously create an error.
As mark_s has already stated, setting option register bit 6 to 0 will enable weak pull ups on GP0, GP1 and GP3
These pins must be set as inputs.
Note, hard pull-ups can always be implemented instead of weak pull-ups.
I trust this helps.
Cheers
Barry
VK2XBP
Well actually I'm going to use a 12F675 as I now find out I can get it programmed. So, on a 12F675 -- how would I enable a pullup on pin 6 GPIO.1 ?
THANKS much.
By the way, "weak" pullup must mean what? Current capabiltiy of the resistor or something?
Try this for setting the pull-up on GPIO.1
OPTION_REG.7 = 0 ' Set global GPPU
WPU.1 = 1 'pull-up on gpio1 enabled
