How should I connect a momentary switch to RB6 and RB7 so I can use them as extra inputs without comprimising the ability of in circuit programing.
Thanks for any help, I think I saw Melanie post about this awhile ago, but I could not find the post.
The simplest way, that I use on all my PCBs is a selector slide switch, DPDT and switch the lines to the input stuff in one position and the programmer connection in the other direction. Works fine, just don't forget to switch back to "RUN" when finished programming.
I normally use a switch like in this schematic http://www.rentron.com/Micro-Bot/Schematic.htm
While both of those methods would work well, I seem to remember Melanie having a simple method of connecting a momentary switch using a pull-up or pull-down resistor that would make it automatic. All I need to use RB6 and RB7 for is as an input for two switches.
It could be half-way down this thread...
http://www.picbasic.co.uk/forum/showthread.php?t=516
Thanks, that must have been where I saw it. So basically set internal pull-ups on the chip and then take RB6/7 to ground through the normally open switch?Quote:
Originally Posted by Melanie
I've got other pins on portB turning on/off leds and I read on the datasheet that when portB is set as an output that the internal pull-ups are automatically turned off. If this is the case can I turn the pull-ups back on and still use half the pins as outputs and half as inputs?
