Csv file transfer directly into excel using vb for serial coms
Hi Guys,
i am looking to run Excel with a VB script running in Excel to capture the CSV data directly
the data would then be available to be directly view fields provided with the Excel sheet
Looking at this link it appears that the coms can be set up to do this with in the vb script running excel
http://dev.emcelettronica.com/serial...n-in-excel-vba
i have not tested this out as yet but it would have some advantages than using a dumb terminal saving the file then loading as i could do the data "live" as an option
it looks like it maybe able to communicate back to the pic via the serial port check if the link is up and file has transfer ok
Was hoping someone has tried this or has something similar than terminal dump program
cheers
Sheldon
Re: Csv file transfer directly into excel using vb for serial coms
It looks interesting the link you post but could not understand how to enable VBA in my Excel and use all these code that appears on te link.
Need a step by step guide on Excel-VBA.
That's a hecka lotta code.
A VB one would be much less work, it seems?
the version shown in the link is for a 32bit version , one here that i am trying to get to run is the 64bit ver
yes there is bit of code in it , but its all copy n paist
Option Explicit
' This VB module is a collection of routines to perform serial port I/O without
' using the Microsoft Comm Control component. This module uses the Windows API
' to perform the overlapped I/O operations necessary for serial communications.
' The routine can handle up to 4 serial ports which are identified with a
' Port ID.
' All routines (with the exception of CommRead and CommWrite) return an error
' code or 0 if no error occurs. The routine CommGetError can be used to get
' the complete error message.
' Public Constants
' Output Control Lines (CommSetLine)
Const LINE_BREAK = 1
Const LINE_DTR = 2
Const LINE_RTS = 3
' Input Control Lines (CommGetLine)
Const LINE_CTS = &H10&
Const LINE_DSR = &H20&
Const LINE_RING = &H40&
Const LINE_RLSD = &H80&
Const LINE_CD = &H80&
' System Constants
Private Const ERROR_IO_INCOMPLETE = 996&
Private Const ERROR_IO_PENDING = 997
Private Const GENERIC_READ = &H80000000
Private Const GENERIC_WRITE = &H40000000
Private Const FILE_ATTRIBUTE_NORMAL = &H80
Private Const FILE_FLAG_OVERLAPPED = &H40000000
Private Const FORMAT_MESSAGE_FROM_SYSTEM = &H1000
Private Const OPEN_EXISTING = 3
' COMM Functions
Private Const MS_CTS_ON = &H10&
Private Const MS_DSR_ON = &H20&
Private Const MS_RING_ON = &H40&
Private Const MS_RLSD_ON = &H80&
Private Const PURGE_RXABORT = &H2
Private Const PURGE_RXCLEAR = &H8
Private Const PURGE_TXABORT = &H1
Private Const PURGE_TXCLEAR = &H4
' COMM Escape Functions
Private Const CLRBREAK = 9
Private Const CLRDTR = 6
Private Const CLRRTS = 4
Private Const SETBREAK = 8
Private Const SETDTR = 5
Private Const SETRTS = 3
' System Structures
Private Type COMSTAT
fBitFields As Long ' See Comment in Win32API.Txt
cbInQue As Long
cbOutQue As Long
End Type
Private Type COMMTIMEOUTS
ReadIntervalTimeout As Long
ReadTotalTimeoutMultiplier As Long
ReadTotalTimeoutConstant As Long
WriteTotalTimeoutMultiplier As Long
WriteTotalTimeoutConstant As Long
End Type
' The DCB structure defines the control setting for a serial
' communications device.
Private Type DCB
DCBlength As Long
BaudRate As Long
fBitFields As Long ' See Comments in Win32API.Txt
wReserved As Integer
XonLim As Integer
XoffLim As Integer
ByteSize As Byte
Parity As Byte
StopBits As Byte
XonChar As Byte
XoffChar As Byte
ErrorChar As Byte
EofChar As Byte
EvtChar As Byte
wReserved1 As Integer 'Reserved; Do Not Use
End Type
Private Type OVERLAPPED
Internal As Long
InternalHigh As Long
offset As Long
OffsetHigh As Long
hEvent As Long
End Type
Private Type SECURITY_ATTRIBUTES
nLength As Long
lpSecurityDescriptor As Long
bInheritHandle As Long
End Type
' System Functions
' Fills a specified DCB structure with values specified in
' a device-control string.
Private Declare PtrSafe Function BuildCommDCB Lib "kernel32" Alias "BuildCommDCBA" _
(ByVal lpDef As String, lpDCB As DCB) As Long
' Retrieves information about a communications error and reports
' the current status of a communications device. The function is
' called when a communications error occurs, and it clears the
' device's error flag to enable additional input and output
' (I/O) operations.
Private Declare PtrSafe Function ClearCommError Lib "kernel32" _
(ByVal hFile As Long, lpErrors As Long, lpStat As COMSTAT) As Long
' Closes an open communications device or file handle.
Private Declare PtrSafe Function CloseHandle Lib "kernel32" (ByVal hObject As Long) As Long
' Creates or opens a communications resource and returns a handle
' that can be used to access the resource.
Private Declare PtrSafe Function CreateFile Lib "kernel32" Alias "CreateFileA" _
(ByVal lpFileName As String, ByVal dwDesiredAccess As Long, _
ByVal dwShareMode As Long, lpSecurityAttributes As Any, _
ByVal dwCreationDisposition As Long, ByVal dwFlagsAndAttributes As Long, _
ByVal hTemplateFile As Long) As Long
' Directs a specified communications device to perform a function.
Private Declare PtrSafe Function EscapeCommFunction Lib "kernel32" _
(ByVal nCid As Long, ByVal nFunc As Long) As Long
' Formats a message string such as an error string returned
' by anoher function.
Private Declare PtrSafe Function FormatMessage Lib "kernel32" Alias "FormatMessageA" _
(ByVal dwFlags As Long, lpSource As Any, ByVal dwMessageId As Long, _
ByVal dwLanguageId As Long, ByVal lpBuffer As String, ByVal nSize As Long, _
Arguments As Long) As Long
' Retrieves modem control-register values.
Private Declare PtrSafe Function GetCommModemStatus Lib "kernel32" _
(ByVal hFile As Long, lpModemStat As Long) As Long
' Retrieves the current control settings for a specified
Private Declare PtrSafe Function GetCommState Lib "kernel32" _
(ByVal nCid As Long, lpDCB As DCB) As Long
' Retrieves the calling thread's last-error code value.
Private Declare PtrSafe Function GetLastError Lib "kernel32" () As Long
' Retrieves the results of an overlapped operation on the
' specified file, named pipe, or communications device.
Private Declare PtrSafe Function GetOverlappedResult Lib "kernel32" _
(ByVal hFile As Long, lpOverlapped As OVERLAPPED, _
lpNumberOfBytesTransferred As Long, ByVal bWait As Long) As Long
' Discards all characters from the output or input buffer of a
' specified communications resource. It can also terminate
' pending read or write operations on the resource.
Private Declare PtrSafe Function PurgeComm Lib "kernel32" _
(ByVal hFile As Long, ByVal dwFlags As Long) As Long
' Reads data from a file, starting at the position indicated by the
' file pointer. After the read operation has been completed, the
' file pointer is adjusted by the number of bytes actually read,
' unless the file handle is created with the overlapped attribute.
' If the file handle is created for overlapped input and output
' (I/O), the application must adjust the position of the file pointer
' after the read operation.
Private Declare PtrSafe Function ReadFile Lib "kernel32" _
(ByVal hFile As Long, ByVal lpBuffer As String, _
ByVal nNumberOfBytesToRead As Long, ByRef lpNumberOfBytesRead As Long, _
lpOverlapped As OVERLAPPED) As Long
' Configures a communications device according to the specifications
' in a device-control block (a DCB structure). The function
' reinitializes all hardware and control settings, but it does not
' empty output or input queues.
Private Declare PtrSafe Function SetCommState Lib "kernel32" _
(ByVal hCommDev As Long, lpDCB As DCB) As Long
' Sets the time-out parameters for all read and write operations on a
' specified communications device.
Private Declare PtrSafe Function SetCommTimeouts Lib "kernel32" _
(ByVal hFile As Long, lpCommTimeouts As COMMTIMEOUTS) As Long
' Initializes the communications parameters for a specified
Private Declare PtrSafe Function SetupComm Lib "kernel32" _
(ByVal hFile As Long, ByVal dwInQueue As Long, ByVal dwOutQueue As Long) As Long
' Writes data to a file and is designed for both synchronous and a
' synchronous operation. The function starts writing data to the file
' at the position indicated by the file pointer. After the write
' operation has been completed, the file pointer is adjusted by the
' number of bytes actually written, except when the file is opened with
' FILE_FLAG_OVERLAPPED. If the file handle was created for overlapped
' input and output (I/O), the application must adjust the position of
' the file pointer after the write operation is finished.
Private Declare PtrSafe Function WriteFile Lib "kernel32" _
ByVal nNumberOfBytesToWrite As Long, lpNumberOfBytesWritten As Long, _
Private Declare PtrSafe Sub AppSleep Lib "kernel32" Alias "Sleep" (ByVal dwMilliseconds As Long)
' Program Constants
Private Const MAX_PORTS = 4
' Program Structures
Private Type COMM_ERROR
lngErrorCode As Long
strFunction As String
strErrorMessage As String
End Type
Private Type COMM_PORT
lngHandle As Long
blnPortOpen As Boolean
udtDCB As DCB
End Type
' Program Storage
Private udtCommOverlap As OVERLAPPED
Private udtCommError As COMM_ERROR
Private udtPorts(1 To MAX_PORTS) As COMM_PORT
' GetSystemMessage - Gets system error text for the specified error code.
Public Function GetSystemMessage(lngErrorCode As Long) As String
Dim intPos As Integer
Dim strMessage As String, strMsgBuff As String * 256
Call FormatMessage(FORMAT_MESSAGE_FROM_SYSTEM, 0, lngErrorCode, 0, strMsgBuff, 255, 0)
intPos = InStr(1, strMsgBuff, vbNullChar)
If intPos > 0 Then
strMessage = Trim$(Left$(strMsgBuff, intPos - 1))
Else
strMessage = Trim$(strMsgBuff)
End If
GetSystemMessage = strMessage
End Function
Public Function PauseApp(PauseInSeconds As Long)
Call AppSleep(PauseInSeconds * 1000)
End Function
' CommOpen - Opens/Initializes serial port.
' Parameters:
' intPortID - Port ID used when port was opened.
' strPort - COM port name. (COM1, COM2, COM3, COM4)
' strSettings - Communication settings.
' Example: "baud=9600 parity=N data=8 stop=1"
' Returns:
' Error Code - 0 = No Error.
Public Function CommOpen(intPortID As Integer, strPort As String, _
strSettings As String) As Long
Dim lngStatus As Long
Dim udtCommTimeOuts As COMMTIMEOUTS
On Error GoTo Routine_Error
' See if port already in use.
If udtPorts(intPortID).blnPortOpen Then
lngStatus = -1
With udtCommError
.lngErrorCode = lngStatus
.strFunction = "CommOpen"
.strErrorMessage = "Port in use."
End With
GoTo Routine_Exit
End If
' Open serial port.
udtPorts(intPortID).lngHandle = CreateFile(strPort, GENERIC_READ Or _
GENERIC_WRITE, 0, ByVal 0&, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, 0)
If udtPorts(intPortID).lngHandle = -1 Then
lngStatus = SetCommError("CommOpen (CreateFile)")
GoTo Routine_Exit
End If
udtPorts(intPortID).blnPortOpen = True
' Setup device buffers (1K each).
lngStatus = SetupComm(udtPorts(intPortID).lngHandle, 1024, 1024)
If lngStatus = 0 Then
lngStatus = SetCommError("CommOpen (SetupComm)")
GoTo Routine_Exit
End If
' Purge buffers.
lngStatus = PurgeComm(udtPorts(intPortID).lngHandle, PURGE_TXABORT Or _
PURGE_RXABORT Or PURGE_TXCLEAR Or PURGE_RXCLEAR)
lngStatus = SetCommError("CommOpen (PurgeComm)")
GoTo Routine_Exit
End If
' Set serial port timeouts.
With udtCommTimeOuts
.ReadIntervalTimeout = -1
.ReadTotalTimeoutMultiplier = 0
.ReadTotalTimeoutConstant = 1000
.WriteTotalTimeoutMultiplier = 0
.WriteTotalTimeoutConstant = 1000
End With
lngStatus = SetCommTimeouts(udtPorts(intPortID).lngHandle, udtCommTimeOuts)
lngStatus = SetCommError("CommOpen (SetCommTimeouts)")
GoTo Routine_Exit
End If
' Get the current state (DCB).
lngStatus = GetCommState(udtPorts(intPortID).lngHandle, _
udtPorts(intPortID).udtDCB)
lngStatus = SetCommError("CommOpen (GetCommState)")
GoTo Routine_Exit
End If
' Modify the DCB to reflect the desired settings.
lngStatus = BuildCommDCB(strSettings, udtPorts(intPortID).udtDCB)
lngStatus = SetCommError("CommOpen (BuildCommDCB)")
GoTo Routine_Exit
End If
' Set the new state.
lngStatus = SetCommState(udtPorts(intPortID).lngHandle, _
lngStatus = SetCommError("CommOpen (SetCommState)")
GoTo Routine_Exit
End If
lngStatus = 0
Routine_Exit:
CommOpen = lngStatus
Exit Function
Routine_Error:
lngStatus = Err.Number
With udtCommError
.strErrorMessage = Err.Description
End With
Resume Routine_Exit
End Function
Private Function SetCommError(strFunction As String) As Long
With udtCommError
.lngErrorCode = Err.LastDllError
.strFunction = strFunction
.strErrorMessage = GetSystemMessage(.lngErrorCode)
SetCommError = .lngErrorCode
End With
End Function
Private Function SetCommErrorEx(strFunction As String, lngHnd As Long) As Long
Dim lngErrorFlags As Long
Dim udtCommStat As COMSTAT
With udtCommError
.lngErrorCode = GetLastError
Call ClearCommError(lngHnd, lngErrorFlags, udtCommStat)
.strErrorMessage = .strErrorMessage & " COMM Error Flags = " & _
Hex$(lngErrorFlags)
SetCommErrorEx = .lngErrorCode
End With
End Function
' CommSet - Modifies the serial port settings.
' Parameters:
' Returns:
Public Function CommSet(intPortID As Integer, strSettings As String) As Long
lngStatus = SetCommError("CommSet (GetCommState)")
GoTo Routine_Exit
End If
lngStatus = SetCommError("CommSet (BuildCommDCB)")
GoTo Routine_Exit
End If
lngStatus = SetCommError("CommSet (SetCommState)")
GoTo Routine_Exit
End If
lngStatus = 0
Routine_Exit:
CommSet = lngStatus
Exit Function
Routine_Error:
With udtCommError
.strFunction = "CommSet"
End With
Resume Routine_Exit
End Function
' CommClose - Close the serial port.
' Parameters:
' Returns:
Public Function CommClose(intPortID As Integer) As Long
lngStatus = CloseHandle(udtPorts(intPortID).lngHandle)
lngStatus = SetCommError("CommClose (CloseHandle)")
GoTo Routine_Exit
End If
udtPorts(intPortID).blnPortOpen = False
End If
lngStatus = 0
Routine_Exit:
CommClose = lngStatus
Exit Function
Routine_Error:
With udtCommError
.strFunction = "CommClose"
End With
Resume Routine_Exit
End Function
' CommFlush - Flush the send and receive serial port buffers.
' Parameters:
' Returns:
Public Function CommFlush(intPortID As Integer) As Long
lngStatus = SetCommError("CommFlush (PurgeComm)")
GoTo Routine_Exit
End If
lngStatus = 0
Routine_Exit:
CommFlush = lngStatus
Exit Function
Routine_Error:
With udtCommError
.strFunction = "CommFlush"
End With
Resume Routine_Exit
End Function
' CommRead - Read serial port input buffer.
' Parameters:
' strData - Data buffer.
' lngSize - Maximum number of bytes to be read.
' Returns:
Public Function CommRead(intPortID As Integer, strData As String, _
lngSize As Long) As Long
Dim lngRdSize As Long, lngBytesRead As Long
Dim lngRdStatus As Long, strRdBuffer As String * 1024
Dim lngErrorFlags As Long, udtCommStat As COMSTAT
strData = ""
lngBytesRead = 0
DoEvents
' Clear any previous errors and get current status.
lngStatus = ClearCommError(udtPorts(intPortID).lngHandle, lngErrorFlags, _
udtCommStat)
lngBytesRead = -1
lngStatus = SetCommError("CommRead (ClearCommError)")
GoTo Routine_Exit
End If
' If udtCommStat.cbInQue > 0 Then
' If udtCommStat.cbInQue > lngSize Then
' lngRdSize = udtCommStat.cbInQue
' Else
' lngRdSize = lngSize
' End If
' Else
' lngRdSize = 0
' End If
lngRdSize = lngSize
If lngRdSize Then
lngRdStatus = ReadFile(udtPorts(intPortID).lngHandle, strRdBuffer, _
lngRdSize, lngBytesRead, udtCommOverlap)
If lngRdStatus = 0 Then
lngStatus = GetLastError
If lngStatus = ERROR_IO_PENDING Then
' Wait for read to complete.
' This function will timeout according to the
' COMMTIMEOUTS.ReadTotalTimeoutConstant variable.
' Every time it times out, check for port errors.
' Loop until operation is complete.
While GetOverlappedResult(udtPorts(intPortID).lngHandle, _
udtCommOverlap, lngBytesRead, True) = 0
If lngStatus <> ERROR_IO_INCOMPLETE Then
lngBytesRead = -1
lngStatus = SetCommErrorEx( _
"CommRead (GetOverlappedResult)", _
GoTo Routine_Exit
End If
Wend
Else
' Some other error occurred.
lngBytesRead = -1
lngStatus = SetCommErrorEx("CommRead (ReadFile)", _
GoTo Routine_Exit
End If
End If
strData = Left$(strRdBuffer, lngBytesRead)
End If
Routine_Exit:
CommRead = lngBytesRead
Exit Function
Routine_Error:
lngBytesRead = -1
With udtCommError
.strFunction = "CommRead"
End With
Resume Routine_Exit
End Function
' CommWrite - Output data to the serial port.
' Parameters:
' strData - Data to be transmitted.
' Returns:
Public Function CommWrite(intPortID As Integer, strData As String) As Long
Dim i As Integer
Dim lngStatus As Long, lngSize As Long
Dim lngWrSize As Long, lngWrStatus As Long
' Get the length of the data.
lngSize = Len(strData)
' Output the data.
lngWrStatus = WriteFile(udtPorts(intPortID).lngHandle, strData, lngSize, _
lngWrSize, udtCommOverlap)
' Note that normally the following code will not execute because the driver
' caches write operations. Small I/O requests (up to several thousand bytes)
' will normally be accepted immediately and WriteFile will return true even
' though an overlapped operation was specified.
DoEvents
If lngWrStatus = 0 Then
GoTo Routine_Exit
ElseIf lngStatus = ERROR_IO_PENDING Then
' We should wait for the completion of the write operation so we know
' if it worked or not.
' This is only one way to do this. It might be beneficial to place the
' writing operation in a separate thread so that blocking on completion
' will not negatively affect the responsiveness of the UI.
' If the write takes long enough to complete, this function will
' timeout
' according to the CommTimeOuts.WriteTotalTimeoutConstant variable.
' At that time we can check for errors and then wait some more.
udtCommOverlap, lngWrSize, True) = 0
"CommWrite (GetOverlappedResult)", _
GoTo Routine_Exit
End If
Wend
Else
lngWrSize = -1
lngStatus = SetCommErrorEx("CommWrite (WriteFile)", _
GoTo Routine_Exit
End If
End If
For i = 1 To 10
DoEvents
Next
Routine_Exit:
CommWrite = lngWrSize
Exit Function
Routine_Error:
With udtCommError
.strFunction = "CommWrite"
End With
Resume Routine_Exit
End Function
' CommGetLine - Get the state of selected serial port control lines.
' Parameters:
' intLine - Serial port line. CTS, DSR, RING, RLSD (CD)
' blnState - Returns state of line (Cleared or Set).
' Returns:
Public Function CommGetLine(intPortID As Integer, intLine As Integer, _
blnState As Boolean) As Long
Dim lngComStatus As Long, lngModemStatus As Long
lngStatus = GetCommModemStatus(udtPorts(intPortID).lngHandle, lngModemStatus)
lngStatus = SetCommError("CommReadCD (GetCommModemStatus)")
GoTo Routine_Exit
End If
If (lngModemStatus And intLine) Then
blnState = True
Else
blnState = False
End If
lngStatus = 0
Routine_Exit:
CommGetLine = lngStatus
Exit Function
Routine_Error:
With udtCommError
.strFunction = "CommReadCD"
End With
Resume Routine_Exit
End Function
' CommSetLine - Set the state of selected serial port control lines.
' Parameters:
' intLine - Serial port line. BREAK, DTR, RTS
' Note: BREAK actually sets or clears a "break" condition on
' the transmit data line.
' blnState - Sets the state of line (Cleared or Set).
' Returns:
Public Function CommSetLine(intPortID As Integer, intLine As Integer, _
Dim lngNewState As Long
If intLine = LINE_BREAK Then
If blnState Then
lngNewState = SETBREAK
Else
lngNewState = CLRBREAK
End If
ElseIf intLine = LINE_DTR Then
If blnState Then
lngNewState = SETDTR
Else
lngNewState = CLRDTR
End If
ElseIf intLine = LINE_RTS Then
If blnState Then
lngNewState = SETRTS
Else
lngNewState = CLRRTS
End If
End If
lngStatus = EscapeCommFunction(udtPorts(intPortID).lngHandle, lngNewState)
lngStatus = SetCommError("CommSetLine (EscapeCommFunction)")
GoTo Routine_Exit
End If
lngStatus = 0
Routine_Exit:
CommSetLine = lngStatus
Exit Function
Routine_Error:
With udtCommError
.strFunction = "CommSetLine"
End With
Resume Routine_Exit
End Function
Private Sub CommandButton1_Click()
Dim intPortID As Integer ' Ex. 1, 2, 3, 4 for COM1 - COM4
intPortID = 3
' Open COM port
lngStatus = CommOpen(intPortID, "COM" & CStr(intPortID), _
"baud=19200 parity=N data=8 stop=1")
End Sub
Private Sub CommandButton2_Click()
Dim strData As String
intPortID = 3
strData = "*IDN?;"
'Writa data
lngStatus = CommWrite(intPortID, strData)
End Sub
Private Sub CommandButton3_Click()
intPortID = 3
lngStatus = CommRead(intPortID, strData, 10)
End Sub
Private Sub CommandButton4_Click()
intPortID = 3
Call CommClose(intPortID)
End Sub
before learning python I used this excel datalogger , it takes up to 12 ascii hex format word vars from the serial port of your choice adds a timestamp ,and some graphs
press the logger button to set it up .
python is so much easier and nicer and more powerful than vb I never used vb ever again esp with SQLite3 db added to the mix
thanks richard
it has less code in it than the other xcell example - it is 32bit but not hard to change that or allow both 32or 64 to run it
the main advantage is excel has vb built in so as long as you can open excel load the work sheet with the macro ( either for 32bit or 64bit ver of the sheet) not need to do more to capture the data coming
i would eventually like to learn python but i have some basic understanding of VB structure and would like to make this work in as short a time as possible
i not done VB for a few years , so setting up the forms , etc need to be reviewed
cheers
sheldon
