Help! I have this code:
I have not shown the mainloop, but it is essentially reading the ADC withCode:;----[16F1826 Hardware Configuration]-------------------------------------------
#IF __PROCESSOR__ = "16F1826"
#DEFINE MCU_FOUND 1
cfg1 = _FOSC_INTOSC ;INTOSC oscillator: I/O function on CLKIN pin
cfg1&= _WDTE_OFF ; WDT disabled
cfg1&= _PWRTE_OFF ; PWRT disabled
cfg1&= _MCLRE_OFF ; MCLR/VPP pin function is digital input
cfg1&= _CP_OFF ; Program memory code protection is disabled
cfg1&= _CPD_OFF ; Data memory code protection is disabled
cfg1&= _BOREN_OFF ; Brown-out Reset disabled
cfg1&= _CLKOUTEN_OFF ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
cfg1&= _IESO_OFF ; Internal/External Switchover mode is disabled
cfg1&= _FCMEN_OFF ; Fail-Safe Clock Monitor is disabled
__CONFIG _CONFIG1, cfg1
cfg2 = _WRT_OFF ; Write protection off
cfg2&= _PLLEN_OFF ; 4x PLL disabled
cfg2&= _STVREN_OFF ; Stack Overflow or Underflow will not cause a Reset
cfg2&= _BORV_HI ; Brown-out Reset Voltage (Vbor), high trip point selected.
cfg2&= _LVP_OFF ; High-voltage on MCLR/VPP must be used for programming
__CONFIG _CONFIG2, cfg2
#ENDIF
;----[Verify Configs have been specified for Selected Processor]----------------
; Note: Only include this routine once, after all #CONFIG blocks
#IFNDEF MCU_FOUND
#ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
#ENDIF
OSCCON = %01101010 '4 Mhz internal clock, PLL off
DEFINE ADC_BITS 10 ' 10 bit A/D Conversion
DEFINE ADC_CLOCK 4
DEFINE ADC_SAMPLEUS 50 ' 50 uS A/D sample time
PORTA = 0
PORTB = 0
TRISA = %00000101 'Set A.0 and A.2 as input, all else Outputs
TRISB = %00000000 'All Outputs
ADCON0 =%00001001 'Turn ON ADC
ADCON1 =%11110000 'Right justified, Internal R/C
ANSELA =%00000100 ' AN2 on PortA.2 Analog
ANSELB =%00000000 ' Digital I/O
adval var word
adcin 2, adval
I cannot get this ADC to work. I need it to read a 0-5V on RA.2.Code:adcin 2, adval
I am wanting to use the INTERNAL oscillator @ 4Mhz.
I have tried for hours. What am I missing please?
Thanks!
