Programming 16F877a PLCC with the melab programmer problem
I try to rpogram the PLCC version of the PIC16F877A with a PLCC to DIP programmer with the melab U2 programmer but it report the device dose not match the selected device,but I can program the DIP version of the same chip,can anybody help me with this issue?
Re: Programming 16F877a PLCC with the melab programmer problem
http://www.microchip.com/forums/m308399.aspx
Is your PIC soldered or are you using a socket?
Are you sure about the orientation of your PIC?
I can program it with a pick it 2 using its pro maker to go function,so I'm sure the mcu is ok,I'm using a adaptor bought from RS components and I've checked the connection,is all ok,and the PIN number is correctl
