Re: Fastest baud rate w/PBP?
		If you're using SEROUT(2) then I think the answer is no. There's a formula that tells you how to specify the baudrate bits and for 115200 the result of that formula comes out negative = no go. I'm not sure but it's possible that DEBUG can work with higher baudrates, it might be worth a shot.
With that said, that chip you're using has an USART, can't you use that?
		Thanks for the reply.  Yes the PIC has a USART, but I need to send serial data out a total of 4 pins...  If you use Mister E's Multicalc, 115200 does give me a number. I have a more precise xtal coming.  Right now my frequency counter says 19.84 MHz which would really screw up the baud rate.  Granted, my  10:1 scope probe could be pulling the frequency that I read.
I'll report back, once I get the new xtals.
JR
 What number does it give?
If you look at the table of numbers for SEROUT2, it pretty much maxes out at 38400.
 You're loading it with the scope probe. Better to measure it a different way.
Even so, while that's not a great number for an xtal it's less than 1% error so the serial baud rate would probably be fine (if that table produces accurate numbers to begin with). I don't think a better xtal is going to do much for you.
Since you're interested in the serial out data, perhaps just transmit a 'U' character ($55) and look at the individual bit times.
