hello guys
im designing something like a washer machine which i need to run the motor right for 5 seconds then left for 5 seconds for hundreds of times
any idea plz to do that
thx
John
hello guys
thx
John
Sure, several but which one to use depends on the specifics - as always.
1) Use a dual supply setup with and connect one side of the motor to GND, use relays or transistors to connect either +xxV or -xxV to other terminal of the motor. Drive the relays or the transitors from the PIC.
2) Use a relay to switch Power to the motor and use another, double pole double throw, relay to switch the polarity of the motor.
3) Use a H-bridge constructed of BJTs, MOSFETs or relays.
4) Use an off the shelf motor drive from AMC, Kollmorgen or whatever.
For the DIY solutions number (3) is the most flexible but also the most complicated one. Depending on the specifications of the motor an off the shelf H-bridge driver IC can possibly be used.
I've used this basic circuit for DC motor directional control. But along with what Henrik said, relays probably aren't the best choice for hundreds of times over and over.
HTH
You can also add an N Channel FET in series with the battery return connection from the relays and be able to do PWM for the motor speed.
