Is there a neater way to do this
I am revising some old code and was wondering if there was an easier way to do this
PARAM1 VAR WORD
PARAM2 VAR WORD
COMMAND VAR BYTE
TX_BUFF VAR BYTE [20]
LEN VAR BYTE
Old code
IF PARAM1.15 THEN
PARAM1 = ABS PARAM1
SerOut2 TX,6, ["SU ", #COMMAND, " -", #PARAM1]
SerOut2 TX,6, ["SU ", #COMMAND, " ", #PARAM1]
IF PARAM2.15 THEN
PARAM2 = ABS PARAM2
SerOut2 TX,6, [" -", #PARAM2]
SerOut2 TX,6, [" ", #PARAM2]
Same code but into an array so I can then send by using
HSEROUT [STR TX_BUFF\ LEN]
Is there an easy way to build the array and keep track of the length (LEN)
Thanks for looking,
Tim.
Re: Is there a neater way to do this
arraywrite TX_BUFF,["SU ", #COMMAND, sdec PARAM1,0]
if you look for the null termination chr then you may not need to know the length or write a subby to determine the length if you have to
Yes, as Richard has shown the SDEC modifier is what you're looking for to get rid of the IF/ELSE/ENDIF stuff but I don't quite understand why you need to build the string, put into an Array and then send it with HSEROUT. Do you need it in the Array for some other purposes? If not, then simply
HSEROUT ["SU ", #COMMAND, " ", SDEC PARAM1]
I'm sure the length of the array, after an arraywrite CAN be extracted from an internal system variable (if done directly after the Arraywrite) but I don't know which. Would need to do some investigation to find out. But again, I don't see the need.
