Variable voltage output from a Pic?
Just wondering if this is possible,
I need a PIC that can give me a variable voltage from aprox. 0-2.5 volts on an output pin.
Can this be done with an Analogue port of a eg.: PIC16F84?
I'm programming in PIC Basic, any source code would be aprecheated.
I need to be able to set multiple pins on my PIC to be different voltages at the same time.
Thanks in advance.
Dan
Re: Variable voltage output from a Pic?
Hey Im looking for help picking a pic suitable for a smoothly stepped voltage between 0 and 10 volts DC over say 5 seconds, Controllable with a button array one that could call for 0v 3v 6v and 10v looking to step in around .3v per step.
Also is there a pic that would support Bluetooth control a swell as the button array
