Serout "onewire.bas"
I have succesfully tried the "one wire.bas" of the samples area with one ds1820 and a 16f876.
Now I'd like to transmit the temperature to a pc but I have been able to receive just the label (C) and the dot and not the numerical value.
Can anybody tell me how to write the serout command in order to read the temperature on the pc?
Thanks a lot.
' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)
LCDOut $fe, 1, DEC (temperature / 100), ".", DEC2 temperature, " C"
' ---------------[University of Bahçeşehir Electrical&Electronics Engineering Final Project]-------------------
' ---------------------------------------[Onur BAŞKİRT - 0111745]--------
' ------------------------------- [DIGITAL TEMPERATURE MEASUREMENT and CONTROL]--------------------------------
'------------------------------------------------[Variables]----------------
temperature VAR WORD ' Temperature storage. (for storing measured value)
count_remain VAR BYTE ' Count remaining
count_per_c VAR BYTE ' Count per degree C
tempc VAR WORD
DQ VAR PORTC.2 ' One-wire data pin. (Ds1820's Dq line connected to RC2)
RX VAR BYTE ' Receive byte from PC.
counter VAR BYTE ' Counter for Automatic Control
state VAR BYTE
maxtemp VAR BYTE
mintemp VAR BYTE
OUTPUT PORTB.5 ' Red led. (Alarm indicator) (or -> TRISB.5 = 0)
OUTPUT PORTB.7 ' Green led.(Device) (or -> TRISB.7 = 0)
INPUT PORTB.1 ' Set portb pin 1 to an input. (or -> TRISB.1 = 1)
OUTPUT PORTC.5 ' Sound output pin. Set portc pin 5 to an output. (or -> TRISC.5 = 0)
OUTPUT PORTC.6 ' Serial comm. output pin. Set portc pin 6 to an output. (or -> TRISC.6 = 0)
INPUT PORTC.7 ' Serial comm. input pin. Set portc pin 7 to an input. (or -> TRISC.7 = 1)
'---------------------------------------------[Includes/Defines]------------
DEFINE LCD_DREG PORTD ' I/O port with LCD. (Defining LCD data port)
DEFINE LCD_DBIT 4 ' When using a 4 bit data bus, (0 or 4) designate beginning of data bits.
DEFINE LCD_RSREG PORTD ' Defining LCD's register port.
DEFINE LCD_RSBIT 2 ' Register select pin.
DEFINE LCD_EREG PORTD ' Defining LCD's enable port.
DEFINE LCD_EBIT 3 ' Defining LCD's enable pin.
DEFINE LCD_BITS 4 ' Defining LCD has 4-bit data bus
DEFINE LCD_LINES 2 ' LCD has two charecter lines
INCLUDE "modedefs.bas" ' Including serial modes.
' Set PORTA and PORTE to digital. Any PICmicro MCU with analog inputs, such as the PIC16C7xx,
' PIC16F87x and PIC12C67x series devices, will come up in analog mode.
' You must set them to digital if that is how you intend to use them: ADCON1 = 7
ADCON1 = 7
PAUSE 100 ' Pause for starting LCD
'-------------------------------------------------[Main Code]-------------
HIGH PORTB.7
counter=0
state=0
maxtemp=29
mintemp=17
' OWOut and OWIn commands are detailly explained in PBP official manual.
' OWOUT Pin,Mode,[Item...]:
' Optionally send a reset pulse to a one-wire device and then writes one or
' more bits or bytes of data to it, optionally ending with another reset pulse.
' Mode of %001 (decimal 1) means reset before data and byte-sized data.
' OWIN Pin,Mode,[Item...]:
' Optionally send a reset pulse to a one-wire device and then read one or
' more bits or bytes of data from it, optionally ending with another reset pulse.
' Mode of %000 (decimal 0) means no reset and byte-sized data, Mode of %100 (decimal 4)
' means no reset and bit-sized data. SKIP for skipping a number of input values.
mainloop: ' Start temperature conversion (send a reset pulse to a one-wire device
OWOut DQ, 1, [$CC, $44] ' on PORTC pin 2 followed by the bytes $CC and $44.)
waitloop:
OWIn DQ, 4, [count_remain] ' Check for still busy converting Read busy-bit
IF count_remain = 0 THEN waitloop ' Still busy..?
OWOut DQ, 1, [$CC, $BE] ' Read the measured temperature (send a reset pulse to a one-wire device
' on PORTC pin 2 followed by the bytes $CC and $BE.)
' This statement would receive bytes from a one-wire device on PORTC pin 0
' with no reset pulse being sent. It would receive 2 bytes skip the next 4 bytes and then read
' the final 2 bytes into separate variables.
OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
' Below formula is given in Ds1820's datasheet. LCDOut prints the values on LCD's screen.
' tempc is binary part of after point. Actual data type of digital temperature sensor.
' For example #tempc is decimal part of after point for example 23.45 C --> #tempc is 23 C
tempc = (temperature / 100)
' SDEC sends signed decimal part of temperature value and SDEC2 sends signed value of temperature before point.
LCDOut $fe, 1, "TEMP: ", SDEC (temperature / 100), ".", SDEC2 temperature, " C"
IF tempc < maxtemp AND tempc > mintemp THEN
LCDOut $fe, $c0, "STATUS OK"
SEROUT PORTC.6, T2400, [#tempc,10]
GOTO automatic
'-----------------------------------------[Automatic and Manuel Control]----------------------------------------
' If temperature is equal or higher than maximum temperature or lower than minimum temperature then led status off and
' Buzzer generates sound also LCD monitors Alarm. Else led status is on, buzzer status off, LCD monitors status OK.
automatic:
IF PORTB.1 = 1 THEN ' Test button value. If button is pressed.
LOW PORTB.7 ' device status is off.
counter=0
SEROUT PORTC.6, T2400, ["disabled",10]
IF tempc >= maxtemp OR tempc <= mintemp THEN ' Test temperature value.
SOUND PORTC.5,[80,10,60,10] ' If temperature higher than maxtemp or lower than mintemp than buzzer generates
' sound that is between 80 & 60 frequency band about 120 ms seconds interval.
LCDOut $fe, $c0, "ALARM!!!" ' LCD monitors ALARM.
Pause 200
GOTO mainloop ' Do it forever
IF PORTB.1 = 0 THEN
SEROUT PORTC.6, T2400, ["notdisabled",10]
IF state = 1 OR state = 2 THEN
HIGH PORTB.5 ' (Alarm indicator) red Led status is on.
SOUND PORTC.5,[40,10,60,10] ' If temperature higher than maxtemp or lower than mintemp buzzer generates
IF tempc < maxtemp AND tempc > mintemp THEN ' Test temperature value.
LOW PORTB.5 ' (Alarm indicator) red Led status is off.
GOTO serial
HIGH PORTB.5 ' LED status is on.
SOUND PORTC.5,[40,10,60,10] ' If temperature higher than maxtemp or lower than mintemp than buzzer generates
counter = (counter + 1) ' Increase +1 automatic control counter.
IF counter = 20 THEN
LOW PORTB.7 ' (Device) green led status is off.
SEROUT PORTC.6, T2400, ["automatic", 10, 13] ' Send automatic data to pc for display warning in pc program.
GOTO serial ' Do it forever
HIGH PORTB.7 ' (Device) green led status is on.
counter=0 ' Reset automatic control counter.
GOTO serial
'------------------------------------------------[Serial Communication]-----------------------------------------
serial:
' ***** [Receive the menu selection from PC] ***************
SERIN PORTC.7, T2400,RX ' Receive menu number
RX = RX - $30 ' Convert ASCII number to decimal (0 = $30, 1 = $31, etc).
SELECT CASE RX
CASE 0
goto zero
CASE 1
goto one
CASE 2
goto two
CASE 3
goto disconnect
CASE IS > 3
goto error
CASE IS < 0
goto error
CASE ELSE
goto mainloop
END SELECT
error:
GOTO mainloop
zero:
state=0
GOTO mainloop
one:
state=1
GOTO mainloop
two:
state=2
GOTO mainloop
disconnect:
LCDOut $fe, $c0, "TURNED OFF "
PAUSE 1000
GOTO mainloop
END ' End of program.
Thank you very much obaskirt for the exaustive program example you sent.
It solves my problem and seems to have most of the features I was planning
for my project.
I am happy for solving your problem, for accomplishing this program, I worked so much. At the beginning of this project, I have not so much info about pic programming.
Anyway, Do your best for your project. Congratulations... n Good Luck.
