Take this action when these numbers are reached. How?
Is there a way to select an action when a specific number is reached in a counter?
For example, if I write:
counter = 0
loophere:
if counter = 21 then counter = 0
counter = counter + 1
goto loophere
What I would like to do is along the lines of:
if counter = 2 or 4 or 6 or 8 or 10 then
led1 = 1
led1 = 0
if counter = 12 or 14 or 16 or 18 or 20 then
led2 = 1
led2 = 0
I know you can write individual lines such as:
if (counter = 2) OR (counter = 4) OR (counter = 6)...then
or
if counter = 2 then
led1 = 1
led1 = 0
if counter = 4 then
led1 = 1
led1 = 0
And so on, but that eats up too much space. Just looking for someone to point me in the right direction. It's late and I'm drawing a blank as to which method to use to save space, but still get it done.
Tony
Re: Take this action when these numbers are reached. How?
select case counter
case 2
do stuff
case 4
do other stuff
case else
do something else
end select
Unfortunately, this is part of a bigger piece of code and right now, I am jumping from a section of code via gosub and running through three gosub subroutines before heading back to the main code. The pic has to read it as the conversation would be spoken: if the counter equals 2 or 4 or 6 or 8 or 10 then turn LED1 on. If it's neither of these numbers, then turn it off.
select case counter
case 2
led1 = 1
case 4
led1 = 1
case 6
led1 = 1
case 8
led1 = 1
case 10
led1 = 1
case else
led1 = 0
end select
or
if (counter = 2 )| (counter = 4) |,,,,, etc then
led1 = 1
led1 = 0
led1 = 1
led1 = 0
That's the simplest way huh? I guess being tired didn't matter. Thanks for the help.
Tony
it depends on how high count goes up to and wether it starts at 0
eq if the count was between 1 and 10 then all that's required is to check bit0 if it set then count is odd therefore led1 is off
Perhaps something like;
If Counter < 11 THEN
If Counter // 2 = 0 THEN
LED1 = 1
LED0 = 0
IF Counter // 2 = 0 THEN
LED2 = 1
LED2 = 0
Can you do something like?
If Counter< 10 then LED1 = Counter.0 : LED2 = NOT LED1
Hi Tony. How about
counter var byte
clear 'all variables
let portb =0 'off everything
loophere:
if counter = (your maximum number) then let counter = 0
let counter = (counter + 1)
let portb = counter
goto loophere
You will have a binary output on portb and can use the appropriate pins depending on the counter number.
Due to the complexity of the rest of the code, I have the main code setting the pause time. The three gosub commands I have written will be immediate, so as not to interfere with the timing cycle of the aforementioned pause.
I have multiple outputs being controlled by two inputs. The outputs must reflect what the inputs are doing in real time, however, two of the outputs must run this code and not affect the timing of the rest of the outputs. A third set of outputs will execute another routine, but that code has already been written and tested. This is the last piece I have to finish.
Using the method I mentioned above, it adds 240 words to my assembly. The way I came up for this program to work in my setup is to have the counter increment with each pass. Half of the count will be dedicated to LED1 and the other half to LED2. It will simply alternate flash the way the code is written.
As I said, the timing portion is set by the main code, so no delays are in these subroutines, and hence, not affect the real time reflection of the inputs.
