First GetADC using DT_Analog.pbp incorrect measurement afterwards is good. Why?
		I am using Darrel Taylor's DT_Analog.pbp for taking analog measurements. Measurements are taken in a loop using GetADC.
The first ADC measurement is always an incorrect value. After the first measurement, all consecutive measurements are correct.
To get around this I do a single measurement first. Then I run my loop to take multiple measurements using GetADC. What is the reason the first measurement is always bad or incorrect?
Your help is always greatly appreciated.
Bryan
		Re: First GetADC using DT_Analog.pbp incorrect measurement afterwards is good. Why?
		Hard to comment without seeing any code.
Does the PIC have time to stabilize before taking the first reading?
What if you add a short PAUSE?
		At least for the 12F683 it has a charge holding capacitor in the ADC circuit.  The way I understand it that needs to be give the appropriate amount of time to charge fully before you take a reading.  That time may change depending on which chip you're using.
My guess is that Demons suggestion of a short pause would solve the problem.  Or a counter that won't allow display until the appropriate time has elapsed.  Either gives the ADC a chance to stabilize and provide the correct reading.
