TIMER1 intterupt of PIC 16f88 in C
Hi;
I'm trying to work ultrasonic sensor (HCSR-04) with PIC16f88. Since other interrutps (RB0 and INT0) were used I'm trying to operate HCSR04 with Timer1.When I connected trigger and echo to oscillator everyting seems OK. I can see trigger and corresponding echo related with distance. I think interrupt never occurs. When I read data sheet of microcontroller I understand as RB6 is related with TMR1 interrupt. Here is my code.
#include <xc.h>
#define _XTAL_FREQ 8000000 // crystal freq defined as 8 Mhz
int b;
void main()
OSCCON = 0b01111000;// 8 Mhz selected Internal Oscillator Freq
INTCON = 0b11000000; // GIE and PEIE is enabled
TRISB = 0b01000000;// RB6 selected as input(echo connected here)
T1CON = 0b01001000; // // System clock is derived from Timer1 oscillator with
// 1:1 prescale value and oscillator is enabled
PIE1bits.TMR1IE=1; // tmr1 overflow is enabled
ei(); // interrupt is enabled
while(1)
TMR1H = 0; //Setting Initial Value of Timer
TMR1L = 0; //Setting Initial Value of Timer
b = 0; // TM1 value is taken in b (look at interrupt at below)
RB5=1;
__delay_us(10); //trigger is sent
RB5=0;
__delay_ms(100); //Waiting for ECHO
if(b>2 && b<=20) // If measured distance is between 2-20 cm led
// at RB1 blinks
RB1=1;
__delay_ms(500);
RB1=0;
if(b>20 ) // If measured distance is higher than 20 cm led // at RB2 blinks
RB2=1;
__delay_ms(500);
RB2=0;
} // while closed
}// main closed
void interrupt echo()
if(PIR1bits.TMR1IF == 1) // Code enters if when flag condition occured
//PIE1bits.TMR1IE=0; // I also tried with that but it didn’t work
T1CONbits.TMR1ON = 1; //Start Timer
if(RB6 == 0) //If ECHO is LOW
T1CONbits.TMR1ON = 0; //Stop Timer
b = (TMR1L | (TMR1H<<8))/58; //Calculate Distance
PIR1bits.TMR1IF=0; //Clear PORTB On*Change Interrupt flag
//PIE1bits.TMR1IE=1;// Enable is opened if it is closed at top
Re: TIMER1 intterupt of PIC 16f88
There are a few here that use "C", but the most of us use Pic Basic. I suggest you try over at the MicroChip forums.
Re: TIMER1 intterupt of PIC 16f88 in C
timer1 is not turned on until the interrupt fires therefore it can't trigger an interrupt. the whole concept is flawed
why no just use portb int on change (its available on a pic16f88 ) portb.rb4:7
