How to use RB1(INT1) as an interrupt?
Okay, I've been trying this all morning with absolutely no luck. Do any of you gracious, knowledgeable programming guru's have a snippet of code just to use RB1 (on the PIC 18F2525 in this instance) as an interrupt. I have tried everything I can think of, I've read countless posts to no avail. I've found info on using RB0 (which I'm using and having no problem with) and even RB4-RB7, but nothing on RB1.
Some say to call out the registers before using the ON INTERRUPT command, the PBP manual and many codes on the forum put them after. Reading the datasheet, I think I set up RB1 as an active interrupt by:
On Interrupt goto some_routine
intcon = %10000000
intcon3 = %00001000
But when I push my momentary switch to simulate an interrupt (goes low), nothing happens. If I stick with the INT0 interrupt solely, everything works beautifully.
My goal is to use two interrupts going to the same interrupt handler, but only have one on all the time. The other would be turned on and off within the program. I'm pretty sure I can figure that out if someone could just show me how to turn on the RB1 (INT1) interrupt. Thanks all!
