This is ok in PBP v2.60c.
Why is this not accepted?Code:IF PORTB.0 = 0 THEN
LCDOUT $FE,$C0,"Row 1, Column 4"
Code:IF PORTB.0 = 0 THEN : LCDOUT $FE,$C0,"Row 1, Column 4" : ENDIF
Yet the manual says I should be able to do it.Quote:
ERROR Line 50: Bad expression.
ERROR Line 50: Bad expression or missing THEN.
Unless IF statements are the exception to the rule?Quote:
2.18 Line-Concatenation ( : )
Multiple commands may be written on a single line using colon characters to tell PBP where to insert a "virtual" line break. This can pack more code into less space, but it generally makes the program more difficult to read.
x = x + 2 : HIGH led : LOW cs
