Incrementing Upper Nibble Only (HighNibble)
Hello Again,
How does one increment only the upper nibble of a byte?
Apparently there is no HighNibble or LowNibble function in PICBASIC?
My goal is to add 1, to the value of Bits [7654] leaving Bits [3210] alone.
And/or how to set just the high bits to some number?
Thanks!
Re: Incrementing Upper Nibble Only (HighNibble)
number var byte
number=number+16 will increment high nibble
number var byte
somenumber var byte
number =$11
somenumber =2
number =(number&$f) |( somenumber<<4 );note (for a meaningful result somenumber <16)
result number=$21
Richard,
Wonderful! Works beautifully!
number var byte
Again, very clean and easy.
Thank you very much!
Jay Zebryk
Zebryk Engineering
Southbridge, Massachusetts
www.zebryk.com
