Lcdout multiple variables issue
Having a problem with the LCDOUT Command on a PIC18F46K22 at 16MHz with a Vishay 4x20 LCD Display.
If I use LCDOUT this way:
LINE1 = $80
LCDOUT $FE, LINE1, "01234567890123456789"
It will work every time flawlessly.
But if I use:
LINE1 = $80
X1 = 10
X2 = 11
X3 = 12
X4 = 13
X5 = 14
LCDOUT $FE, LINE1, #X1, " ", #X2, " ", #X3, " ", #X4, " ", #X5
The display will show
10 11 12 garbage.....
If I do this:
LINE1 = $80
X1 = 10
X2 = 11
X3 = 12
X4 = 13
X5 = 14
LINE1 = LINE1 + 9
GOSUB DELAY30 '30 msec delay
LCDOUT $FE, LINE1, #X4, " ", #X5
then everything is correct
10 12 13 14 15
I tried changing these parameters to no avail
DEFINE LCD_COMMANDUS 1500 ; Set command delay time in us
DEFINE LCD_DATAUS 44 ; Set data delay time in us
Any suggestions?
Re: Lcdout multiple variables issue
If you are trying to display the variable value as decimal, then try using this.
[CODE]
LINE1 = $80
X1 = 10
X2 = 11
X3 = 12
X4 = 13
X5 = 14
LCDOUT $FE, LINE1, Dec X1, " ", Dec X2, " ", Dec X3, " ", Dec X4, " ", Dec X5
This, from the manual: "If a pound sign (#) precedes an Item, the ASCII representation for each digit is sent to the LCD. LCDOUT (on all devices except 12-bit core)"
I use PBP v3 and the DEC output modifier with no issues.
Thank you all for the replies but
also works exactly the same.
The display will show 10 11 12 garbage.....
I need to have a slight delay.
Whether I use #X1 or DEC X1 the output is the same.
I think I'll try creating a 20 byte array then output the array and see what happens
OK here is what I did to solve my issue....
LCDARRAY VAR BYTE[20]
LCD VAR BYTE
LCDHI VAR BYTE
LCDLO VAR BYTE
GOSUB CLEARLCDARRAY
LCD = X1 : GOSUB VALUE2STRING
LCDARRAY(0) = LCDHI : LCDARRAY(1) = LCDLO
LCD = X2 : GOSUB VALUE2STRING
LCDARRAY(3) = LCDHI : LCDARRAY(4) = LCDLO
LCD = X3 : GOSUB VALUE2STRING
LCDARRAY(6) = LCDHI : LCDARRAY(7) = LCDLO
LCD = X4 : GOSUB VALUE2STRING
LCDARRAY(9) = LCDHI : LCDARRAY(10) = LCDLO
LCD = X5 : GOSUB VALUE2STRING
LCDARRAY(12) = LCDHI : LCDARRAY(13) = LCDLO
LCDOUT $FE, LINE4, STR LCDARRAY{\20}
'take the value in LCD and convert it to a 2-character string in LCDHI and LCDLO (ONLY FOR 0 - 99)
VALUE2STRING:
LCDHI = 0
WHILE LCD >= 10
LCDHI = LCDHI + 1
LCD = LCD - 10
WEND
LCDHI = LCDHI + $30
LCDLO = LCD + $30
CLEARLCDARRAY:
FOR LCDCTR = 0 TO 19
LCDARRAY(LCDCTR) = " "
NEXT LCDCTR
