SLEEP
SLEEP Period
Place microcontroller into low power mode for Period seconds. Period is 16-bits, so delays can be up to 65,535 seconds (just over 18 hours).
SLEEP uses the Watchdog Timer so it is independent of the actual oscillator frequency. The granularity is about 2.3 seconds and may vary based on device specifics and temperature. This variance is unlike the BASIC Stamp. The change was necessitated because when the PICmicro executes a Watchdog Timer reset, it resets many of the internal registers to predefined values. These values may differ greatly from what your program may expect. By running the SLEEP command uncalibrated, this issue is sidestepped.
SLEEP 60 ' Sleep for about 1 minute
The above is from the manual. I post it as I do not see the "SLEEP" command in your code.
