I am not able to trigger the interrupt, can Somebody enlight me on what is wrong in the above code?Code:'-------------------------------------------------------------------------------
'| Name : Light_12F683.BAS |
'| Author : |
'| Notice : Copyright (c) 2010 All Rights Reserved |
'| Date : 18/12/2014 |
'| Version : 1.0 |
'| Notes : Pic 12F683 light controller |
' P12F683 (pin usage)
' pin # 1 = Vdd (+ 5 Volts)
' pin # 2 = GPIO.5 (Digital output [Led])
' pin # 3 = GPIO.4 (N/U)
' pin # 4 = GPIO.3 (MCLR)
' pin # 5 = GPIO.2 (Digital output)
' pin # 6 = GPIO.1 (input chan B)
' pin # 7 = GPIO.0 (input chan A)
' pin # 8 = Vss (ground)
;----[12F683 Hardware Configuration]--------------------------------------------
#IF __PROCESSOR__ = "12F683"
#DEFINE MCU_FOUND 1
cfg = _INTOSCIO ; INTOSCIO oscillator: I/O function
cfg&= _WDT_OFF ; WDT disabled
cfg&= _PWRTE_OFF ; PWRT disabled
cfg&= _MCLRE_ON ; MCLR pin function is MCLR
cfg&= _CP_OFF ; Program memory code protection is disabled
cfg&= _CPD_OFF ; Data memory code protection is disabled
cfg&= _BOD_ON ; BOR enabled
cfg&= _IESO_ON ; Internal External Switchover mode is enabled
cfg&= _FCMEN_ON ; Fail-Safe Clock Monitor is enabled
__CONFIG cfg
#ENDIF
;----[Verify Configs have been specified for Selected Processor]----------------
; Note: Only include this routine once, after all #CONFIG blocks
#IFNDEF MCU_FOUND
#ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
#ENDIF
include "ALLDIGITAL.pbp"
DEFINE SHOWDIGITAL 1
INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
DEFINE OSC 8 ' Oscillator frequency
OSCCON = %01110111 ' oscillator setting internal 8 MHz
' ANSEL = %00100000 ' set all digital
' CMCON0 = 7 ' comparator off
OPTION_REG = %11100000 ' weak pullup enabled
GPIO = %00000000 ' set all pins to zero
TRISIO = %00001011 ' configure direction 1=input 0=output
Led var GPIO.5 ' Alias for GPIO.5 pin # 2
A_opto var GPIO.0 ' Alias for GPIO.0 pin # 7
B_Opto var GPIO.1 ' Alias for GPIO.1 pin # 6
Luce var GPIO.2 ' Alias for GPIO.2 pin # 5
wsave VAR BYTE $20 SYSTEM
wsave1 var byte $A0 SYSTEM
A0 var byte
B0 var byte
C0 var byte
F0 var byte
Flag_Count var byte
Flag_In var bit
Flag_Out var bit
Flag_Count = 0
Flag_Out = 0
Flag_In = 0
A0 = 0
B0 = 0
F0 = 0
asm
INT_Handler GPC_INT, _Opto_Read, PBP, yes
@ INT_ENABLE GPC_INT
goto Main
'---------------------------------- Ini ISR ------------------------------------
Opto_Read:
A0 = GPIO & %00000011
If A0 = 1 Then Flag_In = 1
If A0 = 3 and Flag_In = 1 Then Flag_Count = Flag_Count + 1
If A0 = 2 Then Flag_Out = 1
If A0 = 3 and Flag_Out = 1 Then Flag_Count = Flag_Count - 1
@ INT_RETURN
If Flag_In = 1 and Flag_Count > 0 Then
Luce = 1
Flag_In = 0
If Flag_Count > 100 then Flag_Count = 0
If Flag_Out = 1 and Flag_Count = 0 Then
Luce = 0
Flag_Out = 0
Pause 1
F0 = F0 + 1
If F0 > 200 then
Led = !Led
F0 = 0
goto Main ' goes back to main loop
end ' end program
Thank you
Al.
