I try PAUSE 1000 and does'nt seem to pause program 1 seconds. Why?
For large amount of time, Pause does'nt seem to work well, the measured period is less than I expected.
high Led
For i = 1 to 30
next i
low Led
for i = 1 to 30
next i
Above code produced about 1Hz on Led pin and not 1/6Hz!
Re: I try PAUSE 1000 and does'nt seem to pause program 1 seconds. Why?
luxornet
high Led
For i = 1 to 30
next i
low Led
for i = 1 to 30
next i
You are pausing for 3 seconds instead of 1 second.
What's the oscillator frequency and have you used DEFINE OSC xx to inform the compiler OF that oscillator frequency?
I tried with 8MHz resonator and DEFINE OSC 8.
The LCD attached to PIC display data properly and all other thing work well.
Somebody else tried large PAUSE?
Yes, many many many times and never ever have I had an issue.
Which chip?
What version of PBP?
Are you using the default CONFIG?
I didn't read the last sentence of your first post. Yes, besides DEFINE OSC 8, you might need to check on other registers related to the PIC frequency. Does your chip uses the OSCCON register? What chip are you using?
HenrikOlsson
. . . and be sure your define is in ALL CAPITAL LETTERS as Henrik posted, lower case will not work.
